Autor Thema: Raven060 - Aufbau-Abenteuer  (Gelesen 23780 mal)
0 Mitglieder und 5 Gäste betrachten dieses Thema.
Offline Anders Granlund
Re: Raven060 - Aufbau-Abenteuer
« Antwort #180 am: So 18.01.2026, 09:58:26 »
Interessanterweise scheint MagiC das isa_bios.prg nicht zu mögen und läd das einfach nicht.
@Nervengift, I'm following this MagiC testing with great interest!
I recently noticed the issue with isa_bios.prg too but I wrongly assumed it must be related to my local work-in-progress version.
Great that you mentioned the version on Github is also not working correctly, should make it easier to find which recent(?) change broke it :)
« Letzte Änderung: So 18.01.2026, 09:59:04 von Anders Granlund »
Offline Nervengift
« Antwort #181 am: Mo 19.01.2026, 19:31:11 »
@Anders Granlund perhaps it is not a big deal that isa_bios.prg is not working under MagiC. After loading the MagiC Booter the network card driver is loaded from gemsys\magic\xtension. After that all programms from the auto folder are executed. Usually I would place isa_bios.prg in the auto folder after the MagiC Booter, rvnova.prg and nvidi.prg. But could that be an issue if the network card driver is loaded before the ISA P'n'P cards are configurated by isa_bios.prg under MagiC? So I think it does not make a lot of sense to place isa_bios.prg after the MagiC Booter in the auto folder because the network card driver is loaded first?
Currently my using the software release of October 7th, 2025. I hope, I will update the rom and software soon.
Offline Nervengift
« Antwort #182 am: Fr 23.01.2026, 23:15:18 »
@Anders Granlund today I dicovered the following issue: if you load isabios.prg before the Magic Booter isabios may configure the ISA P'n'P cards but after Magic is loaded all information of the ISA P'n'P cards are lost.
Today I just wanted to get my sound card running. Under MagiC oplmidi.prg and mpu401.prg won't find any ISA sound card at all. So I guess MagiC is resetting the ISA bus during the boot process.
My network card is still running under MagiC and found by the eneh.mif driver. I didn't configure my network card as a P'n'P card. Therefore I just jumpered the card to values the driver is expecting the card is set so.
Offline Nervengift
« Antwort #183 am: Fr 23.01.2026, 23:39:31 »
Ich habe heute mal versucht, meine Soundkarte ins System einzubinden. Grundsätzlich müsste das auch geklappt haben, aber ich konnte der Karte noch keine Sounds entlocken. :-[
Also meine Frage an die Experten, habe ich die Karte richtig konfiguriert? oplmidi.prg möchte über Port 388 mit der Karte quasseln und mpu401.prg über Port 330. Beim Port für mpu401.prg bin ich mir sicher, dass ich den richtig eingestellt habe. Beim Port für oplmidi.prg bin ich mir da nicht so sicher. Ich bin einfach mal davon ausgegangen, dass oplmidi.prg nicht über den/die/das MPU401 läuft?
Hier die Werte, auf die die Karte vom isabios.prg konfiguriert wird:
Configured
0 - ID:  PNP0600
    IO:  0376 0170
    IRQ: 15
1 - ID:  OPT9310
    IO:  0534 0388 0220 0e0c
    IRQ: 7
2 - ID:  PNPb02f
    IO:  0200
3 - ID:  OPT0002
    IO:  0330
PNP0600 ist/sind die IDE-Schnittstellen auf der Soundkarte. OPT9310 ist die eigentliche OPTi Audio 16 Soundkarte. PNPb02f ist der Game Port und OPT0002 der/die/das MPU401. So zumindest verklickert mir das das isa_bios.log:
Resources
CARD0 : PNP8036 : NE2000 Ethernet card
CARD1 : OPT0931 : AD931 Audio 16
 DEV0 [02:00] : PNP0600 : IDE CD
  CONF0:
    IO0: 00000376-00000376 : 00000002
    IO1: 00000170-00000170 : 00000008
   IRQ0: 00018000
  CONF1:
    IO0: 0000036e-0000036f : 00000002
    IO1: 00000168-0000016f : 00000008
   IRQ0: 00010400
  CONF2:
    IO0: 000003ee-000003f6 : 00000002
    IO1: 000001e8-000001f0 : 00000008
   IRQ0: 00010800
  CONF3:
    IO0: 0000036e-000003fe : 00000002
    IO1: 00000168-000001f8 : 00000008
   IRQ0: 00010ca0
 DEV1 [02:01] : OPT9310 : OPTi Audio 16
  CONF0:
    IO0: 00000534-00000608 : 00000004
    IO1: 00000380-000003f0 : 0000000c
    IO2: 00000220-00000240 : 00000010
    IO3: 00000e8d-00000e8d : 00000003
   IRQ0: 000102a0
   DMA0: 680b0000
   DMA1: 680b0000
  CONF1:
   IRQ0: 000100a0
   DMA0: 680b0000
   DMA1: 680b0000
  CONF2:
    IO0: 00000530-00000ff0 : 00000008
    IO3: 00000f8d-00000f8d : 00000010
   IRQ0: 000104a0
   DMA0: 680b0000
  CONF3:
    IO3: 00000f0d-00000f0d : 00000010
   IRQ0: 000104a0
   DMA0: 680b0000
  CONF4:
    IO3: 00000e0d-00000ffd : 00000003
   IRQ0: 00010ea0
   DMA0: 680b0000
   DMA1: 680b0000
 DEV2 [02:02] : PNPb02f : Game Port
  CONF0:
    IO0: 00000200-00000207 : 00000001
 DEV3 [02:03] : OPT0002 : MPU401
  CONF0:
    IO0: 00000300-00000360 : 00000002
  CONF1:
   IRQ0: 000106a0
Configured
0 - ID:  PNP0600
    IO:  0376 0170
    IRQ: 15
1 - ID:  OPT9310
    IRQ: 7
2 - ID:  PNPb02f
    IO:  0200
3 - ID:  OPT0002
    IO:  0330
Von daher denke ich, müsste das so passen? Und jetzt stellt sich mir die große Frage wie bekomme ich Töne aus der Karte: Ich habe oplmidi.prg und mpu401.prg in den AUTO-Ordner verfrachtet und die beiden Programme machen unter MiNT auch Meldung, dass sie über die entsprechende Ports mit der Soundkarte quasseln. Aber welches Programm brauche ich jetzt, um Töne zur Karte zu schicken, die sie ausspucken kann? Sorry. In den ganzen Soundkrams stecke ich auch nicht so drin. :-[
« Letzte Änderung: Fr 23.01.2026, 23:41:51 von Nervengift »
Offline Nervengift
« Antwort #184 am: Sa 31.01.2026, 21:01:15 »
Mal ein kleiner Zwischenstand: Mit der Soundkarte bin ich leider nicht weiter. :(
Dafür läuft MagiC etwas runder: Das Shutdown-Programm im GEMDESK-Ordner hat das System zwar runtergefahren, aber wenn man den Button Warmstart oder Kaltstart angeklickt hatte, passierte gar nichts. Der Raven froh dann ein. ShutDown 1.6 für MagiC löst das Problem!
https://alex.barton.de/computer/atari/download/
Mit dem Shutdown-Programm klappen Warm- und Kaltstart ohne Probleme und das Programm bietet noch ein paar mehr Möglichkeiten als das Original. Wie es scheint ist alles, was im GEMDESK- bzw. MGXDESK-Ordner des aktuellen MagiC-Builds liegt, vermurkst. Zumindest läuft das auf dem Raven anscheinend nicht so rund.
Netzwerk unter MagiC ... bzw. Probleme mit der Namensauflösung: Das hat sich auch mehr oder weniger erledigt. Alles, was nach MagiCNet, StinG/StiK, iConnect usw verlangt, läuft! Was allerdings Probleme macht, ist Software, die nach MiNTNet verlangt. Vor allem neuere Programme, die MiNTNet erfordern, laufen gar nicht unter MagiC.
Offline Nervengift
« Antwort #185 am: So 22.02.2026, 19:46:51 »
Gestern auf dem RCT#38 in Hannover haben @LarryL und ich auf meinem Raven060 das aktuelle Software Release vom 17.02.2026 installiert und auch das ROM aktualisiert. Leider hat das aktuelle Release ein paar unerwünschte Nebenwirkungen auf meinem Vogel:
- Die Bootauflösung wird nicht korrekt umgesetzt: Die Schrift wird zusammengestaucht und erscheint "fett" auf dem Monitor. Es wird nur die obere Hälfte des Bildschirms genutzt. Beim Laden des Desktops unter EmuTOS und MiNT/XaAES wird die Auflösung dann wieder korrekt eingestellt.
- Das Booten von MagiC bricht dem Vogel die Flügel. Beim Laden des Nova-Treibers wird die Auflösung nicht mehr korrekt eingestellt. Es scheint so, dass NVDI noch geladen wird, aber dann passiert nichts mehr. Die Auflösung für den Desktop kann anscheinend gar nicht mehr eingestellt werden.
EmuTOS und MiNT/XaAES laufen zwar grundsätzlich mit dem aktuellen Release, aber mir waren die Einschränkungen dann doch zu groß, so dass ich zurück auf das Software-Release vom 07.10.2025 bin. Damit läuft mein Vogel ohne große Probleme.
Ich denke, dass der überarbeitete Nova-Treiber des Raven mit meiner Grafikkarte nicht klarkommt. Es ist ein wenig ein Glücksspiel mit den Grafikkarten und dem modifizierten Nova-Treiber. Ist aber auch ein Mammutaufgabe bei der Anzahl an Karten und Varianten, die es alleine von den ET4000-Karten gibt, fürchte ich.
Hier die Release History des Raven Software Releases: https://github.com/agranlund/raven/releases/tag/Raven.A1.latest
Offline Nervengift
« Antwort #186 am: So 22.02.2026, 19:52:06 »
In meinem Raven nutze ich eine COLORGRAPHIC COMMUNICATIONS CORPORATION Super Warp (ET4000/W32I) und eine Rev. 5 68060 CPU, die ich mit 48 MHz (x1) betreibe.
Offline yalsi
« Antwort #187 am: Mo 23.02.2026, 19:19:18 »
...und ich ärgere mich gerade mächtig, bei euch in der Kuschelecke nicht neugieriger gewesen zu sein. Den Thread und die Infos auf Github habe ich mir durchgelesen und bin jetzt motiviert, einen Artikel für die nächste LOAD zu schreiben. Ich melde mich dann mit der Beta-Version bei euch :-)
Offline Nervengift
« Antwort #188 am: Mo 23.02.2026, 19:41:23 »
Das wäre mal eine echt coole Sache. Vielleicht ist @Anders Granlund auch bereit ein kleines Interview zu geben?
Offline Nervengift
« Antwort #189 am: Fr 27.02.2026, 21:26:03 »
Inzwischen gibt es ein neues Release vom 25.02.2026, das das Problem mit der gestauchten Bootauflösung löst. Magic läuft auf meinem Raven aber auch weiterhin nicht (mehr) mit der Version vom 25.02.2026. Es gibt teilweise Berichte von Benutzern, die Magic auf dem Raven installieren möchten und die Installation will nicht. Ich denke, das könnte ggf. auch mit dem Release (ROM) zu tun haben, was man einsetzt.
Offline Nervengift
« Antwort #190 am: Sa 28.02.2026, 23:03:19 »
Bislang war ich daran gescheitert 2 Laufwerke an dem 44 Pin-Anschluss des Raven zu betreiben. Ich hatte für meine Versuche eine 80 GB 2,5 Zoll Festplatte verwendet, die mir wohl das häufige Umstecken übel genommen hat und sich verabschiedet hatte. Die machte keinen Mucks mehr. Ich war mit der eh nicht ganz glücklich und wollte auch eine einfachere Möglichkeit haben, Daten mit anderen Systemen auszutauschen. Also hatte ich nochmal so geschaut, was es für Möglichkeiten gibt und mich für folgenden Adapter entschieden:
InLine® Schnittstellenkarte, IDE 6,35cm (2,5") auf 2x CF Karte
https://www.inline-info.com/InLine-Schnittstellenkarte-IDE-6-35cm-2-5-auf-2x-CF-Karte
Der Adapter ist inzwischen eingetroffen und jetzt funktioniert das auch mit 2 Laufwerken im Raven! Ich habe u. a. eine 4 GB CF-Karte, mit der mein CF-Kartenadapter im Milan nicht klarkommt und auch der Delock-Adapter, den ich mir mal für ein anderes Projekt zugelegt hatte, kommt mit der besagten CF-Karte nicht klar. Für den InLine-Adapter ist diese Karte kein Problem!
Was allerdings bei dem Adapter nicht ganz ideal ist: Man erkennt nicht so ohne weiteres Pin 1. Dazu muss man eine Taschenlampe bemühen und auf das PCB schauen, um die Beschriftung zu erkennen. Ein weiteres Problem war für mich, dass mein 44 Pin-IDE-Kabel eine entsprechende Nase hat für die Aussparung auf der männlichen Anschlussseite. So ließ sich das Kabel aber nicht auf den Anschluss des InLine-Adapters stecken. Die Nase stößt ans Gehäuse. Also das Gehäuse aufschrauben und das PCB einmal um 180° drehen. Ich war allerdings zu faul dazu und habe stattdessen meinen Byte-Swap-Adapter, dessen Anschlussstecker keine Nase hat, auf den Stecker des Adapters gesetzt. Da sitzt er sogar besser bzw. stabiler als auf der Hauptplatine, finde ich und er funktioniert genauso gut.
Mein InLine®-Adapter ist übrigens heute (endgültig) gestorben und hat leider dabei die eine 16 GB CF-Karte, die ich von @bbisi bekommen hatte, mit in den Tod gerissen. :(
Ich hatte in letzter Zeit öfters mal das Problem, dass ich Lesefehler bekam oder Daten nicht geschrieben werden konnten. Gestern eskalierte das auf dem Vogel komplett und verursachte beim Booten ein krasses Durcheinander. Das ging dann soweit, dass der Vogel auch hin und wieder mal abstürzte und anfing, komplett instabil zu fliegen. Dann machte sich ein Geruch nach durchgeknallter Elektronik breit. :o
Ich habe erstmal wieder einen Single-CF-Kartenadapter eingebaut. Ein Glück hatte ich vorgestern ein Image von den CF-Karten gezogen, so dass ich das Image zurückspielen konnte. Ich muss mal sehen, was es da noch so an 44 Pin-Adaptern gibt.
Letzten Endes bin ich ganz glücklich darüber, dass der Tod des InLine®-Adapters dem Vogel nicht die Flügel gebrochen hat. Der scheint immerhin hart im Nehmen zu sein.
Offline bbisi
« Antwort #191 am: Mo 09.03.2026, 20:48:56 »
Gerade gefunden
CPU Wechsel Tool
https://centuriontech.eu/product/060pgatool/
Offline Nervengift
« Antwort #192 am: Mi 08.04.2026, 22:40:02 »
Ich habe mal meinen Raven060 die aktuelle Systemsoftware gegönnt:
Das Update verlief soweit ohne große Probleme. Bis auf auf MagiC. Beim Booten von MagiC blieb selbieges beim Laden des Nova-Treiber mit der Fehlermeldung STA_VDI not found! hängen obwohl alle Dateien an korrekter Ort und Stelle waren. Nach einigen Nachforschungen stellte sich heraus, dass dieser Fehler nicht auftritt, wenn ich auf die Verwendung der autoexec.bat verzichte.
In der autoexec.bat sind die Auto-Ordner-Programme aufgeführt, die MagiC beim Booten ausführen soll. Man muss dazu nicht zwangsläufig die autoexec.bat verwenden, aber ich hatte das auf dem Milan so eingerichtet und auf dem Raven hatte ich das Problem, wenn ich die autoexec.bat nicht nutze, dass nach dem Laden des MagiC-Booters XBOOT nochmal ausgeführt wird, was einerseits nicht weiter dramatisch ist, weil das keine Probleme macht, aber doch nervt, weil es den Bootvorgang unnötig verlängert.
In der aktuellen Raven-Systemsoftware ist auch eine für den Raven060 angepasste XBOOT-Version enthalten. Ich habe, die XBOOT-Version, die ich auf dem Raven genutzt hatte, durch die aus dem aktuellen Systemsoftwarepaket ersetzt. Mit der Version aus dem Systemsoftwarepaket, wird XBOOT nach dem Laden des MagiC-Booters nicht nochmal ausgeführt.
In der Kombination XBOOT aus dem aktuellen Raven-Systemsoftwarepaket und auf die autoexec.bat verzichten bootete MagiC dann wieder ordungsgemäß und ich habe sogar ein paar Probleme, die ich vorher mit MagiC hatte, nicht mehr:
  • Beim Booten fragte MagiC immer Datum und Uhrzeit ab, weil anscheinend nicht die RTC ausgelesen werden konnte. Das funktioniert jetzt und die Abfrage kommt beim Booten nicht mehr.
  • Das isa_bios.prg wird jetzt auch beim Booten von MagiC ausgeführt und die ISA-Karten während des Bootvorgangs entsprechend konfiguriert.
Was ich als nächtes nochmal angehen möchte ist die Soundkarte und schauen, ob ich mit Hilfe der aktualisierten Treiber endlich Töne aus derselben herausbekomme.
« Letzte Änderung: Mi 08.04.2026, 22:41:29 von Nervengift »
Offline Nervengift
« Antwort #193 am: Sa 11.04.2026, 20:49:47 »
Insofern werde ich sehr wahrscheinlich erstmal die Karte mit Opti-Chipsatz als nächstes ausprobieren und schauen ob ich die mit J602 des Raven-Boards verbinden kann. Müsste ich nur die genaue Pinbelegung herausbekommen.
Mal schnell nen Screenshot gemacht
Das Verbinden von J602 mit der Soundkarte ist übrigens ganz einfach: Der schwarze Stecker eines CD-Audiokabels, mit dessen Hilfe man das Audiosignal optischer Laufwerke an die Soundkarte überträgt, passt genau auf J602. Auf dem Raven-Board ist J602 entsprechend gekennzeichnet, so dass man das Kabel auch eigentlich nicht falsch anschließen kann.
Die CD-Audiokabel gibt es auch mit unterschiedlichen Steckern, falls der Anschluss auf der Soundkarte ein anderer sein sollte. Man braucht also kein Kabel selbst basteln zu diesem Zwecke. 8)
Offline Nervengift
« Antwort #194 am: Sa 11.04.2026, 21:46:43 »
Soundkarten im Raven060 ... eigentlich ganz einfach, wenn man die richtige erwischt ...
Die Soundkarte mit dem OPTi 82C931 Chipsatz, die ich in meinen Vogel verpflanzt hatte ist "nur" Soundblaster Pro kompatibel, was dem Raven aber anscheinend nicht ausreicht. Die Karte und ihre Komponenten werden zwar korrekt erkannt, aber ruft man rvsctrl.prg mit dem Parameter devs auf, dann fehlt der Eintrag 0201 unter mixer und im GSXB Mixer sind alles Regler auf 0 und können nicht verstellt werden.
Der Raven braucht anscheinend etwas, was Soundblaster kompatibel ist. Ansonsten wird die Soundkarte einfach mehr oder weniger ignoriert. Also habe ich nochmal zu einer anderen Karten aus meinem Fundus gegriffen: Soundblaster AWE 64 (CT4500)
Nach dem Tausch habe ich nochmmal rvsctrl.prg mit dem Parameter devs aufgerufen und der Eintrag 0201 unter mixer ist dann vorhanden. Im GSXB Mixer sind die Regler dann entsprechende der rvsnd.inf voreingestellt und können verändert werden. Ich werde midi-out mal auf die Soundkarte (MPU401, OPL) umstellen und schauen, was für Töne dann so aus der Karte herauskommen.
@Anders Granlund hatte auch zwei Videos zum RVSND-Treiber veröffentlicht:
https://www.youtube.com/watch?v=6m3R6jq827I
https://www.youtube.com/watch?v=c3Dia7kWLPk
Offline Nervengift
« Antwort #195 am: Mi 22.04.2026, 21:40:28 »
Ich habe noch folgende Informationen zu den Soundkarten bzw. Midi im Exxos-Forum von @Anders Granlund gefunden:
Music has an explanation:
- By default, midi messages are sent to the midi-out jack on the motherboard. You'll need an external midi synth to get actual audio.
- The MPU401 driver re-routes midi messages to MPU401 device on the ISA bus, such as soundblaster, or the picogus in SB mode, or other cards with a compatible device.
What the card does with these messages is up to it but generally speaking they usually won't produce audio but rather forward the messages out their own midi jack, requiring an external midi synth to get actual audio.
If your card has a wavetable header then it can send the midi messages to it, and that wavetable synth will produce actual audio. This is the most convenient solution to get audio from midi.
- The OPLMIDI driver is a software synth that works in the background. It consumes the midi messages and tries to play something sensible on OPL2/3 device if you have one on of these on the ISA bus. (I'm sure there can be bugs in this code, and if so, fixes are welcome :) )
(Tyrian plays Adlib music rather than midi which is why you are hearing it regardless of midi driver)
I don't have a good answer for the lack of SFX in Tyrian and ScummST. The audio code should be very similar to the one in Doom but perhaps some bug or something initialization related missing, like hardware volume or something like that perhaps.
I forget, can your default pcm audio volume be set by pgusinit? Perhaps you have it set to 0 by default and I am setting it to something sensible in Doom but not in the other ones (just wildly guessing since it works here for me)
So wie ich das jetzt verstehe, braucht man für Midi immer einen separaten Synthesizer, es sei denn man nutzt den OPL auf der Soundkarte? Wenn man den Midi-Krams auf dem Raven entsprechend über den OPL routet, sollte die Soundkarte also Töne ausspucken oder verstehe ich das falsch?
