Autor Thema: Atari PC file transfer.  (Gelesen 14344 mal)
Offline Mark
« am: So 17.12.2023, 19:06:51 »
Is there a possibility to transfer files from an Atari PC to a more modern PC, with windows 10, over the serial port ?
I've a nul modem cable, but don't find programs for a proper communication.
I know INTERLNK/INTERSVR, but those works only in a dos environment.
Thinks in advance,
Mark
Re: Atari PC file transfer.
« Antwort #1 am: So 17.12.2023, 19:11:06 »
I know that people run the venerable Ghostlink under DOSBox on the PC: https://www.jamesfmackenzie.com/2016/02/06/use-rs232-serial-cable-and-ghostlink-to-transfer-files-from-pc-to-st/. Then there is the much newer https://github.com/z80andrew/SerialDisk. Still, you need a way to get the respective program to the Atari in the first place.
EDIT: The paragraph above applies to an Atari ST, not an Atari PC!
« Letzte Änderung: So 17.12.2023, 20:26:03 von czietz »
« Antwort #2 am: So 17.12.2023, 19:27:58 »
If your PC has a parallel port, or your Atari has an USB interface, you might also want to have a look at
https://joy.sophics.cz/parcp/
« Antwort #3 am: So 17.12.2023, 20:18:46 »
Do you refer to an Atari PC (8088 or later, Intel) or an Atari ST (Motorola 68000, TOS)?
On the Windows side, use Hyperterm, ZOC, TeraTerm.
For the ST:
  • CoNnect
  • STarCall
  • Rufus as Terminal Software (all can do ZMODEM transfers)
  • On old TOS versions (non-MagiC), you better replace the TOS serial drivers by newer ones (HSMODEM).
You’d still need a disk (floppy) to get some software onto the ST. Or a cartridge port/ACSI port harddisk, based on CompactFlash or SD card media.
For Atari PCs with MS-DOS/DR-DOS …:
… or Telix or Telemate …
If you need to "kickstart" the old PC, there’s a minimal Terminal software that you can enter in DEBUG.
« Letzte Änderung: So 17.12.2023, 22:44:55 von gh-baden »
« Antwort #4 am: So 17.12.2023, 20:24:51 »
Ah, I have totally misread/overlooked that you wrote about an "Atari PC". Sorry! My advice applies to an Atari ST. Thank you, @gh-baden for pointing this out.
« Letzte Änderung: So 17.12.2023, 20:26:20 von czietz »
Offline Mark
« Antwort #5 am: Mo 18.12.2023, 00:00:14 »
Thanks to all for the quick reply.
It indeed concerns an Atari PC1 with a  8088 processor, and DOS.
PS, On my 680x0 machines, I use the Netusbee with uip-tool.
Have a nice eventing,
Mark
« Letzte Änderung: Mo 18.12.2023, 00:07:29 von Mark »
« Antwort #6 am: So 24.12.2023, 00:29:28 »
I also have an Atari PC1 and use a CF card for data transfer.  I got an 8bit dual IDE card and also built a board for the special expansion port of the Atari PC1 with two 8bit slots).  I have a cf card on one port via ide2cf, where the system for the Atari PC1 is on it, and I communicate externally with the cf card on the second ide port.
https://forum.atari-home.de/index.php/topic,16608.0.html
From #12 onwards.
This doesn't answer your question about serial data transfer, but it works better and faster, and is also suitable for larger data.
« Letzte Änderung: So 24.12.2023, 00:31:40 von Gaga »
Offline Mark
« Antwort #7 am: Mo 25.12.2023, 16:23:33 »
Nice work  :)
I'll check it out after holidays, when I'm back home.
