Autor Thema: Nova VME Bus Grafikkarten Adapter Projekt ...  (Gelesen 242097 mal)
Offline Bikerbob
Re: Nova VME Bus Grafikkarten Adapter Projekt ...
« Antwort #120 am: Mo 13.04.2020, 23:49:42 »
The VOFA Mega ST Bus adapter is for TSENG ET4000AX only.
So are you saying I cant run the Ati Mach32 on the Pak68/3?
James
« Letzte Änderung: Mo 13.04.2020, 23:54:49 von Bikerbob »
« Antwort #121 am: Di 14.04.2020, 07:50:25 »
In a VOFA Mega ST Bus Adapter no. But it work with a Panther or Panther/2 Adapter. Driver are on Idek´s Website ->   https://silicon-heaven.org/atari/nova/Panther2/
The GALs are on the PAK Website. There are a different GAL for ET4000, MACH32 or MACH64 ->   http://www.wrsonline.de/software/WRSGAL04.zip
« Letzte Änderung: Di 14.04.2020, 07:55:33 von Lukas Frank »
Offline Bikerbob
« Antwort #122 am: Di 14.04.2020, 16:37:11 »
Thanks so much Frank.  mods done to Nova and OGFA programmed. I am trying  it today! :)
James
Offline Bikerbob
« Antwort #123 am: Mi 15.04.2020, 18:20:55 »
Fired up first try on the OGFA GAL !
Super happy!
« Antwort #124 am: Mi 15.04.2020, 18:37:23 »
The GAL and the Patches are made by the Lightning Team ...
Offline Bikerbob
« Antwort #125 am: Fr 17.04.2020, 02:01:10 »
Super happy!
Frank by the picture I put up top. What kind of RAMDAC do I have? what should I be able to get out of this Mach32 2mb?   So far all I can get is 800x600 64k.. nothing higher.  still nice picture though.
« Antwort #126 am: Fr 17.04.2020, 08:45:43 »
Ask @Idek Tramielski ...
But the picture in post #118 show a little 110Mhz RamDAC like the Bt RamDAC. Try the VMG at 1024x768/64k colours, but you can destroy the RamDAC and the card. So I think 800x600/64k colours is max.
->   https://forum.atari-home.de/index.php/topic,14398.0.html
« Letzte Änderung: Fr 17.04.2020, 09:36:57 von Lukas Frank »
« Antwort #127 am: Fr 17.04.2020, 13:03:34 »
try my sta_vdi.bib with 1024x768/64k Colors ...
Offline Bikerbob
« Antwort #128 am: Fr 17.04.2020, 15:14:02 »
Hey frank where were you able to use this test program you show here
https://forum.atari-home.de/index.php/topic,14398.msg227754.html#msg227754
« Antwort #129 am: Fr 17.04.2020, 15:24:43 »
m32utl.zip is a msdos software. You need a PC with ISA Slots ...
http://cd.textfiles.com/monstmedia/UTILS/DRIVERS/
Offline Bikerbob
« Antwort #130 am: Fr 17.04.2020, 21:16:24 »
Ok, working on this.. and using your VESA TIMING SIGNAL LINK - thanks Frank.. like that. but I have a question in regards to using VMG .. not sure what I Should or should not modify.
looking at this pic. I am trying to setup 1280x960 x2 as per TT030 high res.   As you can see in the pic.. I do get a picture.. but its nasty and the bottom quarter is messed up. Now  there is the section where you can input I assume the monitor frequencies.. you can see I put my monitor maxes in.. do I do that?  81 HORZ and 75 Vert.  I dont understand how to calculate pixel timing.. I see on VESA SIGNAL site http://tinyvga.com/vga-timing/1280x960@60Hz  that timing is 102.1  my screen says 100
The horizontal and vertial totals match..
How do I improve this screen?
This is using your STA_VDI.BIB frank
« Antwort #131 am: Fr 17.04.2020, 22:15:23 »
Set first under "Frequencies:" the "Pixel Clock" to your max = 110Mhz and "Save Parameters" ...
When you use a modern LCD or TFT all Resolution can have Vertical Frequenz = 60Hz that is fine. The BIB Files are all fine. Your Monitor have a moiré at the high 1280 resolution, try 1024 and that would be fine.
« Letzte Änderung: Fr 17.04.2020, 22:21:15 von Lukas Frank »
« Antwort #132 am: So 26.07.2020, 18:13:15 »
GALs in DIL werden rar. Habe mir einen PLCC Adapter gemacht.
guest522
« Antwort #133 am: So 26.07.2020, 19:02:05 »
Kann ich nicht bestätigen. Ich habe  gerade
20 x 16V8
20 x 20V8
20 x 22V10
für insgesamt ca. €40 inkl. Versand aus China erhalten. Nur einer war defekt, was mich überrascht hat.
« Antwort #134 am: So 26.07.2020, 19:21:36 »
Ja stimmt ...
Die PLCC waren neu von Kessler
« Antwort #135 am: Mi 07.10.2020, 13:31:20 »
Das ist zur Zeit der aktuelle VME-ISA Adapter ...
Offline Patrick STf
« Antwort #136 am: Do 10.12.2020, 02:01:08 »
Hallo Frank,
ich hab endlich Deinen Adapter in meinem TT. Dort ist eine Mach 64 mit 2 MB verbunden. Wie installiere ich nun die Karte unter TOS und wo gibt es den passenden Treiber ? Übrigens die Lösung mit dem externen Gehäuse gefällt mir sehr gut. LG
Patrick
« Antwort #137 am: Do 10.12.2020, 08:23:00 »
https://silicon-heaven.org/atari/nova/TT030/Mach64/
Bootreihenfolge
emulator.prg
menu.prg
sta_vdi.prg
« Antwort #138 am: Do 10.12.2020, 08:35:12 »
@Patrick STf ... wo hast du denn die 2MB MACH64 her? Ist eine der 300,- Euro Ebay Karten die angeblich nur mit 1MB laufen?
Offline Patrick STf
« Antwort #139 am: Do 10.12.2020, 21:53:47 »
Aus einer Atari Gruppe auf Facebook. Hab vor einem Jahr ca. 130 Euro bezahlt.
Patrick
