Hatari 2.3.0 erschienen
goetz @ 3rz:
--- Zitat von: czietz am Sa 28.11.2020, 20:23:08 ---Ein kleines "Easter Egg" (naja, wirklich versteckt ist es nicht) gibt es auch: Legt mal das mitgelieferte Disk-Image hatari_23.msa in Laufwerk A: ein und bootet Hatari mit Atari-STE-Emulation (und Farbmonitor).
--- Ende Zitat ---
Doppe-Noice! Sowohl die 2.3 wie auch so ein Schmankerl :-)
Arthur:
Hatari 2.3 unter Windows 10. Gibt es einen Trick dem Falcon TV mit 60HZ zu entlocken? Obwohl ich NTSC und TV in Bootconf gewählt habe steht in der Statusanzeige unten TV 50HZ und bei Sysinfo PAL.
czietz:
Ich zitiere einfach mal im Wortlaut:
--- Zitat ---it seems Santa had still some extra gifts for us, as he just brings a
new release of Hatari :)
This v2.3.1 is mainly a bugfix release, fixing a few issues that were
reported after v2.3.0 was released
You can get it from https://hatari.tuxfamily.org/ or directly in
https://download.tuxfamily.org/hatari/2.3.1/
Sources are available, as well as prebuilt binaries for Windows (in 32
bit and 64 bit mode) and macOS (thanks to Troed).
(note that the Windows binaries don't include PortAudio/PortMidi
libraries for now, only macOS version does)
Main changes since Hatari 2.3.0 :
- Hatari could crash when switching to Falcon mode and no IDE drive
was used
- Fix unneeded extra prefetch for movem in 68020/30 CPU
- Fix master clock use for crossbar/DSP Handshake mode
- Fix hostport PORTB interrupt handling for DSP
- FPU setting did not work in macOS version for french language
- Fix Hatari window disappearing in the python UI when changing resolution
This improves several Falcon demos/programs that had bad sound or
triggered bus error unless MMU was enabled.
See release-notes.txt for the full changelog
http://hatari.tuxfamily.org/doc/release-notes.txt
No new intro this time, but you can still enjoy the one from Hatari
2.3.0 made by Evil/DHS and spkr/SMFX.
Get it here https://download.tuxfamily.org/hatari/demos/hatari_2.3/ or
here https://www.pouet.net/prod.php?which=87497
Nicolas
--- Ende Zitat ---
Arthur:
Mal an getestet und läuft.
Arthur:
Geile Software... Hatari in Fullscreen mit 2048x1152 in sw das macht richtig Spaß. Werde später noch ein Screenshot posten.
Navigation
[0] Themen-Index
[*] Vorherige Sete
Zur normalen Ansicht wechseln
