Autor Thema: ST-Paint.  (Gelesen 20019 mal)
guest3221
ST-Paint.
« am: Sa 22.09.2012, 20:56:30 »
Hi all.
i have made an Atari St drawing program for windows,
if you like to try a beta then you can download over at Atari forum.
http://www.atari-forum.com/viewtopic.php?f=14&t=23971
or you can grab it on my home page.
fedepede04.dk
go under ST-Paint.
ST Paint BETA version
http://www.youtube.com/watch?v=VJ254Q90tS4&feature=relmfu
ST-Paint Palette Function
http://www.youtube.com/watch?v=_4XdEtf2T2Y
guest3221
Re: ST-Paint.
« Antwort #1 am: Fr 28.12.2012, 00:16:56 »
Post copy from atari-forum.com
Hi All.
I had hope to uploaded a new version before Christmas, but it could not achieve that, due to back pain(can only sit in front of a computer for a short time).
and i had also hope to complete more of the function.
But i have decided to upload a newer version any way, since lot had happened to the program compared to the last version.
new thing in the program.
windows mode (not complete)
Clipboard : Remember the last 15 clip
Color Replacer : Use to replace a color somewhere in the graphic
Poly Line :
Load/save Neochrome picture.
Load Degas Under/Overscan Picture*
and some of the functions have been change.
like the undo buffer in the polygon function, (now while drawing a polyg, and undo you will remove the last point, when finish the polyg and undo, you will remove the hole polygon.
the program is in the first post.
if you try or use the program, and you have time then some feedback would be nice.
*Under/Overscan Picture function.
Under/Overscan Picture function is made with help from Ben Jos Walbeehm the author of "Atari ST Plus Picture Viewer" probable the best Atari viewer for the PC.
due to my back problems, i have not got it to work 100%, but it load most of them, but the under/overscan routine can be turn off.
viewtopic.php?t=23952
Best Regards
Peter
guest3221
Re: ST-Paint.
« Antwort #2 am: Mo 31.12.2012, 17:05:50 »
Hi All i have just uploaded a new version to Atari-Forum.com
I have add Full screen more shortcut and a couple of other things
This will probably be the last time, that I post about the program here, due to no interest in the program, so keep a eye out for updates over at Atari-forum.
and a Good New Year to all.
Best Regards
Peter
Re: ST-Paint.
« Antwort #3 am: Mo 31.12.2012, 18:29:51 »
fedepede04, you may want to post a link to your website and the download section here....
Not everyone over here has an account at atari-forum.com to get access to your files posted there.
rastr
Re: ST-Paint.
« Antwort #4 am: Mo 31.12.2012, 21:09:15 »
guest3221
Re: ST-Paint.
« Antwort #5 am: Mo 31.12.2012, 22:49:02 »
Got Ya
guest3221
Re: ST-Paint.
« Antwort #6 am: Mo 31.12.2012, 22:57:14 »
Hi all
right now my site only have and old version,
but till i got my homepage updated, you can use this link
https://dl.dropbox.com/u/3083462/ST-Paint%2031.12.2012.rar
Re: ST-Paint.
« Antwort #7 am: Di 01.01.2013, 13:41:33 »
Hi all
Thanks.
Please let us know, as soon as your website has been updated.
guest3221
Re: ST-Paint.
« Antwort #8 am: Di 01.01.2013, 14:34:51 »
will do
then i hope that some can use it
