Autor Thema: Wanted - Graphics Card for TT  (Gelesen 16656 mal)
guest3186
« am: So 25.03.2012, 05:39:21 »
Hi, now that i have my yamaha CBXD5 unit working with Cubase Audio CBX, i would like to get the best resolution that i can to run Cubase on my TT.
I have read about an atari monitor TT195 that will give a resolution of 1280 x 960. I would like to buy a graphics card for the TT that will get me as close to this resolution as possible.
Please excuse my use of english as my german is not good.
If anyone has a graphics card for the TT that would suit my needs please pm me here.
Thank you very much,
kind regards,
blaylok
Arne
Re: Wanted - Graphics Card for TT
« Antwort #1 am: So 25.03.2012, 09:16:14 »
Just plug-in a TTM194/195 into your TTs Monitor outlet and the TT detects the monitor and switches to 1280x960x2 on its own. No drivers needed.
guest3186
« Antwort #2 am: So 25.03.2012, 10:13:47 »
Hi Arne,
Thanks for the reply, unfortunately i don't have a TT195 monitor. I would like a graphics card instead so that i can plug the TT into my TFT 19" monitor.
« Antwort #3 am: So 25.03.2012, 11:24:21 »
I think that Cubase will not run on any Graphics Card.
So the TTM195 is the best choice ...
guest522
« Antwort #4 am: So 25.03.2012, 14:15:36 »
Are you sure about this Frank? Cubsae 2.06 at least runs on a CTPCI Radeon. Though, I have not tested it on a Nova yet.
« Antwort #5 am: So 25.03.2012, 14:38:08 »
I'm not sure ...
May be someone can test it !
