Autor Thema: Wanted - Cubase Audio CBX  (Gelesen 20923 mal)
guest3186
« am: Sa 17.03.2012, 21:47:36 »
Hi there, i am after a working version of Cubase Audio CBX to run on my TT.
I have two Yamaha CBXD5 units that i would like to get going with my TT.
So far all i have been able to get is a corrupt version of Cubase audio CBX that keeps on bombing out on the TT.
Thank you,
kind regards,
blaylok
Re: Wanted - Cubase Audio CBX
« Antwort #1 am: Sa 17.03.2012, 21:51:45 »
... die Version vom Steinberg FTP Server hat er schon und die Bombt !
« Antwort #2 am: So 18.03.2012, 11:44:32 »
« Antwort #3 am: So 18.03.2012, 14:01:13 »
3 Cubase Audio & Atari TT System
An overview
In this system the CBX-D5 is used with an Atari TT computer and the supporting
software is Cubase Audio by Steinberg.
What you will need
1) The CBX-D5, a power cable, two MIDI cables, a 50-way SCSI cable, and a SCSI
terminator (all these except for one MIDI cable are provided with the CBX-D5).
2) An Atari TT computer and an Atari video monitor.
3) Steinberg’s Cubase Audio software (Atari version).
4) A SCSI hard disk and a 25-pin D-SUB to 50-way SCSI cable.
Making the connections
1) Connect the Atari computer’s “MIDI OUT” connector to the CBX-D5’s “MIDI IN”
connector, and the computer’s “MIDI IN” connector to the CBX-D5’s “MIDI OUT”
connector using the MIDI cables.
2) Connect the Atari computer’s “SCSI” connector to the hard disk’s SCSI connector
using the 25-pin D-SUB to 50-way SCSI cable.
3) Connect the other hard disk SCSI connector to one of the CBX-D5’s SCSI
connectors using the 50-way SCSI cable.
4) Insert the CBX-D5’s SCSI terminator into the CBX-D5’s unused SCSI connector.
5) Connect the CBX-D5 to an AC receptacle using the supplied power cable.
6) Connect the Atari computer and its video monitor to an AC receptacle.
Settings
1) Set the CBX-D5 to SCSI ID “5 or 6” using the thumb wheel switch on the rear of the
CBX-D5.
2) Set the CBX-D5’s “TO HOST” switch to “MIDI”.
3) Set the hard disk to SCSI ID “1” (refer to its Operating Manual for details).
Quelle: http://www2.yamaha.co.jp/manual/pdf/emi/english/synth/CBXD5E1.pdf
Offline cyberish
« Antwort #4 am: So 18.03.2012, 14:40:34 »
I did not try it myself, but people report that the Cubase - Version here does the trick:
http://atari.music.free.fr/main.php?Cubase%20Audio
best, raphael
guest3186
« Antwort #5 am: Mo 19.03.2012, 20:18:21 »
Hello, Thank you everyone here for the advice.
I will try what you all have suggested and report back here as to how i go with it.
blaylok
Offline rian_ata
  • Proud to be an Atarian!
« Antwort #6 am: Di 20.03.2012, 00:03:00 »
In einen anderen Thema habe ich schon einen link zu einem Teil das Handbuch verlinkt auf meine Seite. Es soll laufen auf einem TT:
http://forum.atari-home.de/index.php?topic=2536.msg66533#msg66533
http://www.atarian.nl
guest3186
« Antwort #7 am: So 25.03.2012, 05:32:01 »
Hello to all,
Thank you very much for all of the advice given to me by the members of this forum.
I have finally gotten it all working great! Now i am able to use my yamaha CBXD5 with cubase audio without any problems. :)
Thank you very much,
kind regards,
blaylok
« Antwort #8 am: So 01.04.2012, 11:28:10 »
Hier noch ein LINK aus dem atari-forum.com, angeblich die Version 1.0.2 ...
http://doyeuxyvan.free.fr/cubase/CAFCBXD5/
http://www.atari-forum.com/viewtopic.php?f=33&t=20843#p207215
... es soll mit dem roten Dongle vom Cubase 3 funktionieren !
« Letzte Änderung: So 01.04.2012, 13:21:24 von Lukas Frank »
guest899
« Antwort #9 am: So 01.04.2012, 13:11:29 »
Hier gibt es die Version 1.1 , wahrscheinlich das letzte Cubase Audio CBX update:
