Autor Thema: Multi-Sync cable  (Gelesen 17110 mal)
guest2484
Multi-Sync cable
« am: Mi 14.07.2010, 16:43:18 »
Hi, any know or where i can buy a multi-sync cable, for monitor EUM-1491A? I search shematics or something for make something like this:
http://www.ataricomputers.altervista.org/ATARI_FALCON_030_MULTISYNC_CABLE_VGA_RGB.htm
thx!!
Re: Multi-Sync cable
« Antwort #1 am: Mi 14.07.2010, 18:04:04 »
Hallo Enito, here a picture from the EUM-1491A backside.
Look in this Archiv (the Falconarchiv inside) and here are some adapter schematics.
« Letzte Änderung: Mi 14.07.2010, 18:45:01 von Arthur »
guest2484
« Antwort #2 am: Mi 14.07.2010, 18:51:53 »
Arthur,
again thx!! valuable information... you can make one with rgb/vga switch? i pay for this of course, or any place for buy one. Because get db19 here is hard, and dont wanna kaput :P
I see in the docs you give me,
file:///C:/Books/DOITF030/080202.htm
This one is like the one i wanna make, but is db19 to hd15, ineed to db25 hheh
Thx
regards
« Antwort #3 am: Mi 14.07.2010, 19:07:34 »
Sorry, i can't. I need one monitor with ttl for testing and a little more space for working. I think you are the one for this. :D
Good luck! ;)
guest2484
« Antwort #4 am: Mi 14.07.2010, 19:11:10 »
Good luck! ;)
Hhaha np, thx anyways...but..where i can schema for DB19 to DB25 with switch , i dont wanna boom :P
thx!
edit: apprently i found one hehe
