Autor Thema: Installation von NetBSD  (Gelesen 41525 mal)
Offline Beetle
Re: Installation von NetBSD
« Antwort #20 am: So 21.02.2010, 13:58:40 »
ich stehe mit Izumi in Kontakt, hier mal der letzte Mailwechsel.
Er lässt hoffen. (>> ich / > Izumi / ich)
Izumi Tsutsui schrieb:
> Hi,
>> i read you're working on the Atari port of NetBSD. I'd like to see a
>> driver for
>> the EtherNec (and Hydra / NetUSBee, since they all use same software on
>> TOS and share the same chip) .
>> This cheap network upgrade connects to ROM port of the Atari.
>> Of course you can't develop or debug without having the hardware.
>> I have a spare EtherNec (Romport Adapter and Realtek RTL8019 ISA
>> Ethernet card) i'd happy provide in case you want to support it.
>> Just drop me a mail if you want it. I'd love to see my Falcon on the net
>> with NetBSD.
> Hmm, I'm currently building SMC-TT Ethernet for TT030.
> (the rest work is wiring for bus signals but it will take several days)
Thats cool.
> I was also told about EtherNEC before, but I chose SMC-TT
> because it had interrupt support and I was a bit lazy
> to build PCB for ROM cartridge slot using etching.
> (I already have 8019 based ISA boards so ROMport Adapter is enough)
my Adapter is soldered to the ISA card (i didn't have an ISA slot at hands)
> I've checked driver sources and hardware schematic of EtherNEC,
> and I think it would be trivial to write a driver for NetBSD.
> (though I'm afraid polling ops won't provide so good performance)
Sure, performace wise its suboptimal. I get around 400kByte/s Transfer rate on my Falcon. Fast enough for Atari needs...
> Is the EtherNEC more popular than SMC-TT among most Atari users?
> If so I could help them once I get a ROMport adapter..
Yes, it is by far the most used and most available network solution on Atari. Also it can be used from plain 1040ST up to the fastest Falcon060, including the clones that have ROM port. EtherNec, NetUSBee and Hydra are all opened projects, that are free to rebuild by anyone.
VME based solutions are rare and expensive. You won't get a used old VME based Ethernet card below 100 Euro, where a new shiny Hydra costs 25 Euro (readily built and tested) and i paid 18 Euros for my EtherNec.
We also consider to provide you a free Hydra, since its a very size-reduced Version of the EtherNec concept. A really neat ROMport Ethernet card.
Greetings,
Stefan
« Antwort #21 am: So 21.02.2010, 14:39:02 »
Das habe ich Sinngemäß auch an das Atari-NetBSD Team gesendet. ;D
Offline Beetle
« Antwort #22 am: So 21.02.2010, 20:03:23 »
Je mehr Feedback, um so besser :-D
« Antwort #23 am: Mo 08.03.2010, 00:37:00 »
Hallo Athur, teste doch mal bitte den Kernel auf deinem Atari TT ob er läuft.
grüße
  frank
Hallo Frank, ich habe es so gemacht wie Du es mir erklärt hast. Also LOADBSD.TTP und NETBSD_ATARITT.GZ (vor dem Kopieren schon nach NETBSD) direkt auf Laufwerk C: kopiert. Der Bildschirm wurde weiß und der Cursor blinkte in der Linken oberen Ecke herum. :D Dann dachte ich mir das Netbsd direkt die CrazyDots umgeht und habe den VGA Monitor von der CrazyDots and die Atari TT VGA-Buchse umgehängt. Auf dem Bild siehst Du das es wohl geklappt hat.
Mein Atari TT hat die Mainboardrevision H. Er ist mit 64MB FastRAM (dank dir) und 4MB ST-RAM ausgestattet.
Atari TT Netbsd-Screen
« Letzte Änderung: Mo 08.03.2010, 00:51:36 von Arthur »
« Antwort #24 am: Mo 08.03.2010, 11:52:13 »
Hallo Arthur, dann weiss ich auch nicht mehr warum NetBSD bei mir nicht bootet.
Kann nur daran liegen das ich nur alte Daugther Board Atari TT Rechner habe.
grüße
  frank
« Antwort #25 am: Mo 08.03.2010, 16:33:41 »
Hallo Frank, hast Du schon mal die alter 4er Version oder die ganz neue 5.02er vom 09.02.2010 getestet?
« Antwort #26 am: Mo 08.03.2010, 17:14:29 »
Hallo Arthur, egal welche Version es läuft nicht. Scheint halt so zu sein das es
da doch Unterschiede zwischen den alten Boards und den neueren gibt.
grüße
   frank
--- news zum Netzwerk am VME Bus ---
Yesterday I finished building the SMC_TT1 VME-ISA bridge circuit.
Today I've written MD attachment code of MI we(4) driver for NetBSD/atari,
and now it works fine. Yay!
Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005,
    2006, 2007, 2008, 2009, 2010
    The NetBSD Foundation, Inc.  All rights reserved.
Copyright (c) 1982, 1986, 1989, 1991, 1993
    The Regents of the University of California.  All rights reserved.
NetBSD 5.99.24 (ATARITT) #68: Tue Mar  9 01:19:59 JST 2010
   tsutsui@mirage:/usr/src/sys/arch/atari/compile/ATARITT
Atari TT (m68030 CPU/MMU mc68882 FPU)
total memory = 69632 KB
avail memory = 65104 KB
timecounter: Timecounters tick every 15.625 msec
mainbus0 (root)
avmebus0 at mainbus0
vme0 at avmebus0
leprobe: cannot map memory-area
we_vme_probe: WE_PROM: 00 00 c0 3f 87 ed 2b 61
we_vme_probe: WE_ROM_SUM: 0xff
we0 at vme0 port 0xfe200280-0xfe20029f iomem 0xfe0d0000-0xfe0d3fff irq 4
we0: SMC8216 with SMC_TT VME-ISA bridge Ethernet (16-bit)
we0: Ethernet address 00:00:c0:3f:87:ed
% ifconfig we0
we0: flags=8863<UP,BROADCAST,NOTRAILERS,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   address: 00:00:c0:3f:87:ed
   media: Ethernet manual
   inet 192.168.20.45 netmask 0xffffff00 broadcast 192.168.20.255
   inet6 fe80::200:c0ff:fe3f:87ed%we0 prefixlen 64 scopeid 0x1
% ping -n -s 1472 192.168.20.1
PING 192.168.20.1 (192.168.20.1): 1472 data bytes
1480 bytes from 192.168.20.1: icmp_seq=0 ttl=255 time=10.091 ms
1480 bytes from 192.168.20.1: icmp_seq=1 ttl=255 time=12.044 ms
1480 bytes from 192.168.20.1: icmp_seq=2 ttl=255 time=12.044 ms
1480 bytes from 192.168.20.1: icmp_seq=3 ttl=255 time=11.963 ms
1480 bytes from 192.168.20.1: icmp_seq=4 ttl=255 time=11.963 ms
^C
----192.168.20.1 PING Statistics----
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 10.091/11.621/12.044/0.856 ms
% netstat -in
Name  Mtu   Network       Address              Ipkts Ierrs    Opkts Oerrs Colls
we0   1500  <Link>        00:00:c0:3f:87:ed      361     0      286     0     0
we0   1500  192.168.20/24 192.168.20.45          361     0      286     0     0
we0   1500  fe80::/64     fe80::200:c0ff:fe      361     0      286     0     0
lo0   33192 <Link>                                 5     0        5     0     0
lo0   33192 127/8         127.0.0.1                5     0        5     0     0
lo0   33192 ::1/128       ::1                      5     0        5     0     0
lo0   33192 fe80::/64     fe80::1                  5     0        5     0     0
I'll post more details later. (it's time to sleep ;-)
Izumi Tsutsui
« Letzte Änderung: Mo 08.03.2010, 18:56:27 von Lukas Frank »
« Antwort #27 am: Di 09.03.2010, 13:06:49 »
Ich weiß nicht ob es wichtig ist aber der Atari TT den ich benutzt habe, hat noch eine original Atari 16MB Fastramkarte eingebaut und nicht wie angegeben die Magnum TT mit 64MB. Bitte keine Anfragen für Test's diesbezüglich stellen, sobald ich den anderen TT wieder mal angeschließe hole ich das nach...irgendwann.
« Antwort #28 am: Di 09.03.2010, 14:08:23 »
Hallo Arthur, an der Fastramkarte liegt es nicht.
grüße
  frank
Offline m0n0
« Antwort #29 am: Di 09.03.2010, 19:54:38 »
Hallo Frank,
Du schreibst die Fehlermeldung sei zu kurz zu sehen.
Evt. kannst Du es mal mit dem Util. Slow-Down probieren:
http://www.deltalabs.biz/atari-pd-serie-2051.htm
bzw.: http://www.shiftwork.de/atari/2/P_2060.ZIP
Es wäre doch zu schade nicht herauszubekommen wo der Fehler liegt - wenn man schon so einen schönen Boot-Up Screen zu sehen hat ;)
Gruß!
Offline cyberish
« Antwort #30 am: Mi 24.03.2010, 20:44:47 »
Offline m0n0
« Antwort #31 am: Mi 24.03.2010, 20:58:06 »
Krasse scheisse, habt ihr das Netzwerk-Karten "teil" gesehen?   Wie geht denn das..., da muss sich aber einer gut auskennen 8)
« Antwort #32 am: Mi 24.03.2010, 23:03:34 »
Ja, Izumi Tsutsui scheint ein echter Crack zu sein. Ein schönes GIF gibts auch noch auf der Seite.
Gruß Arthur
Offline Beetle
« Antwort #33 am: So 28.03.2010, 19:54:57 »
Ich bekam grad eMail...
No problem, finally I've built EtherNEC cartridge adapter
and interface board from scratch, and now EtherNEC driver
for NetBSD/atari is almost working :-)
I'll post details to NetBSD mailing list later.
Izumi Tsutsui
Cool!
« Antwort #34 am: So 28.03.2010, 20:56:57 »
Ich habe das SMC_TT projekt auch hier gehabt aber habs nie zuende gebracht und an irgendwem weiter gegeben. Glaub an Frank
Da ich nun nen CT60 Falcon habe. Würde ich mich auch einmal mit dem NetBSD Beschäftigen.
« Antwort #35 am: So 23.05.2010, 11:44:34 »
Atari TT bootet NetBSD mit SMC_TT Netzwerkkarte ...
http://www.youtube.com/watch?v=R_EdT8QWAkQ
Info´s unter ...
http://www.netbsd.org/ports/atari/
Offline Beetle
« Antwort #36 am: So 23.05.2010, 12:02:31 »
4 Minuten bis zum Login  ;D
Aber es läuft!
Auf dem Falcon 060 bootet es übrigens deutlich flotter. Wer bringt NetBSD nun bei, das der Falcon einen PCI Bus mit Radeon-Grafikkarte haben könnte?
Gruss,
Stefan
