Autor Thema: Updated GFA-BASIC Library released  (Gelesen 16576 mal)
Offline draconis1
  • ATARIaner seit 1987
« am: Fr 09.10.2009, 13:49:20 »
Ok here it is, finally ready. This actually brings with it a new compiler and linker. If you don't read the docs please note that the components of this archive must not be mixed with older versions.
I've been working on this for a very long time and it contains 127 updated modules. The library is now interrupt free, and hopefully bug free. See the docs for a very long list of changes and corrections.
List of features:
Mostly bug fixes and enhancements.
No radical changes to the library for maximum backward compatibility.
Enhanced CPU/FPU support for machines with an 020 CPU or better (optional).
Unused code removed.
This library is actually smaller than the original library.
Improved MiNT compatibility.
Some small optimizations were done as well.
Line-A use only where it should be used.
Improved error handler with advanced debugging options.
Break key can now be cleanly used in compiled applications.
EVERY/AFTER are now cleanly implemented.
Improved hardware detection for STE only commands.
All vector hooks removed (except $B+ which is optional).
If you have any problems or the docs are unclear, please let me know. I'll do my best to help.
Enjoy.
Grab it here: Direkt zum download
Online simonsunnyboy
Re: Updated GFA-BASIC Library released
« Antwort #1 am: Fr 09.10.2009, 18:10:32 »
Ahhh - der neue GFABASIC Compiler von Lonny Pursell :)
Geiles Teil! Auf meinem STE habe ich es noch nicht probiert, sollte aber laufen. Der Compiler und die Lib geht mit Hatari, unter Hatari wird bei Verwendung der GEMDOS Harddisk (gemapptes PC Directory) auch der .gfa.gfa Bug gefixt!
Schöne Sache!
PS: lp freut sich immer über direktes und durchaus auch konstruktives Feedback :)
« Antwort #2 am: Fr 09.10.2009, 19:54:51 »
Für alle, die zu faul zum Nachschauen im ZIP sind:
Die Lib kommt mit einem neuen Compiler und läuft _nicht_ mit dem orginalen Compiler. Der neue ersetzt den alten allerdings pluginmäßig und völlig unproblematisch.
Am besten eine gute GFA Shell anstelle von MENU.PRG benutzen!
