Autor Thema: NetBSD Atari-port  (Gelesen 15851 mal)
frank.lukas
NetBSD Atari-port
« am: Di 09.12.2008, 11:09:45 »
It's similar trace that I had with Falcon and 030 cpu: ...
buf_mrelease() & pool_put() :/ and I was installing from hard disk; so
it might happen to again if you try w/o networking. If you have time
you could try it. However in 060 mode I was able to continue
installation but kernel panicked with ATA errors later (probably
different root cause...).
Maybe it's still worth to email ATARITT and FALCON kernels with pmap
and Tsutsui's patches to port-atari to see if we can find more testers
(currently I'm only one with Falcon: )).
-Tuomo
please Mail to ... tjamaloo@gmail.com
Re: NetBSD Atari-port
« Antwort #1 am: Di 09.12.2008, 11:14:24 »
Geht das in Deutsch???
Mein Englisch ist et so gut!! Aber sucht der Tester?
« Letzte Änderung: Di 09.12.2008, 12:55:42 von tuxie »
frank.lukas
« Antwort #2 am: Di 09.12.2008, 15:53:31 »
Ja es werden Tester gesucht und vor allem eine Spende in Form eines
alten Atari TT 4/4, HD Floppy, TOS 3.06 ...
Der Atari Port ist seit der Version 1.6 nicht mehr so richtig lauffähig ...
Ich habe zwar eine Version 3.1.1 auf meinem TT aber nur mit einem
Kernel ohne Netzwerk support. Zur Zeit ist die Version 5 in der Mache ...
--- unterstützte Hardware ---
ST and TT video modes, including TT-HIGH
Falcon video (except Direct Color - 15/16 bit depth)
Hades et4000/w32-pci video adapter
Hades et6000-pci and et6100-pci video adapter
Builtin 5380 SCSI adapter
Most SCSI disks, CD-ROM's, tape's and ZIP drives
Realtime clock
SCC serial ports (serial2/modem2)
720Kb/1.44Mb floppy drive
Parallel printer
The IDE interface on both Falcon and Hades (Including ATAPI)
The serial interface on the first 68901 UART (modem1)
68060 support for the Hades
The Falcon FX memory expansion
The atari mouse
A 3-button mouse (see build description)
Supported VME-bus devices (TT030/Hades)
VME BVME410 ethernet
Circad Leonardo 24-bit VME graphics adapter
Crazy Dots VME et4000 graphics adapter
VME Riebl (and possibly PAM) ethernet
Supported Hades PCI-devices
Adaptec 2940U SCSI NOT (see the note below)
ESS Technology Inc. Solo-1 Soundcard
3Com 3c59x Network card
Supported Hades ISA-devices
I4BSD support for the teles 16.3 card
NE2000 compatible cards
Supported Milan PCI-devices
Intel EtherExpress PRO 10+/100B
Weitere Info's gibt es auf www.netbsd.org unter ports/atari und in den Maillisten
grüße
  Frank
« Letzte Änderung: Di 09.12.2008, 16:41:20 von frank.lukas »
frank.lukas
« Antwort #3 am: Mi 10.12.2008, 19:44:15 »
Kernel sind vorhanden für ...
- Atari TT
- Atari Falcon
- Hades
- Milan
... untersützt wird auch die CT60 mit 040 sowie 060er Support. Wenn man von einem i386 BSD sich einen eigenen Kernel kompilert ist wahrscheinlich der port auch auf normalen Atari ST mit PAK/3 lauffähig. Das minimale System ist ein 68030 mit 4MB ST sowie Fastram oder mehr als 4MB ST Ram.
Der Betreuer in Schweden hat nur einen Falcon, ein Tester aus den USA hat einen TT und ein Programmierer aus Japan der schon ein paar Patches geschrieben hat, hat gar
keinen Atari.
Ich weiss nicht wie der NetBSD Atari Port auch Hades und Milan laufen da ich keine Geräte habe. Aber bei mir läuft außer dem 3.1.1 auf dem Atari TT noch eine Version 4.01 auf einem alten 233Mhz imac und ich muss sagen das daß
NetBSD schon recht gut ist auf alter Hardware mit einem einfachen XServer und TWM als Desk und dann den Firefox starten. Zur Zeit ist zwar der Firefox noch nicht Bestandteil in den 68k Ports aber das kommt bestimmt noch ... !
Ansonsten sind die Quellen der einzelnen Versionen alle die gleichen.
Zudem ist das MiNT sowie OS X sehr nach am BSD dran ...
grüße
  Frank
« Letzte Änderung: Mi 10.12.2008, 19:49:24 von frank.lukas »
« Antwort #4 am: Do 11.12.2008, 10:50:51 »
Also das klingt doch mehr als Interessant, ich bau meinen Milan auf und dann gehts los. Theoretisch sollten doch da sogar andere Grafikkarten möglich sein oder?
Wer macht mit?
Machen wir ein Deutsches Tut?
frank.lukas
« Antwort #5 am: Fr 12.12.2008, 19:12:56 »
Die Anleitungen zum Atari Port sind einigermassen übel ...
Zum ersten Test reicht es wenn man sich die Kernel Versionen vom
NetBSD Ftp Server holt. Auf der Partition C:\ einfach mit
   gzip.ttp -d name.gz
den Kernel entpacken und dann mit
   loadbsd.ttp -Db netbsd
den Kernel laden. Wenn dann der Rechner einwandfrei bootet kann man versuchen die entsprechende Version zu Installieren. Bei den TTP programmen alle Dateinamen in der Eingabe Zeile klein schreiben.
md2a ist das HD Floppy Laufwerk für die Installation. Man braucht nur eine
HD Diskette mit sysinst.fs drauf. Erstellen der Diskette, erst formatieren als PC
Diskette und dann mit
   rawrite.ttp -H sysinst.fs
die Diskette erstellen.
loadbsd.ttp
a
b
d       /* Output debugging output?   */
h      /* show help         */
N       /* No symbols?         */
o
s       /* St-ram only         */
S
t       /* Just test, do not execute   */
T
v       /* show version         */
w
[-abdhstVD] [-S <stram-size>] [-T <ttram-size>] [kernel]
-a  Boot up to multi-user mode.\r
-b  Ask for root device to use.\r
-d  Enter kernel debugger.\r
-D  printout debug information while loading\r
-h  What you're getting right now.\r
-N  No symbols must be loaded.\r
-o  Write output to both <output file> and stdout.\r
-s  Use only ST-compatible RAM\r
-S  Set amount of ST-compatible RAM\r
-T  Set amount of TT-compatible RAM\r
-t  Test the loader. It will do everything except executing the\r
    loaded kernel.\r
-V  Print loader version.\r
-w  Wait for a keypress before exiting.\r
frank.lukas
« Antwort #6 am: So 14.12.2008, 17:53:17 »
Hi, wich Packages I need to build a ATARITT NetBSD Kernel under a
NetBSD 4 macppc Port ?
If you have all of the source (*) checked out, you can use /usr/src/build.sh:
  sh /usr/src/build.sh -m atari tools
  sh /usr/src/build.sh -m atari kernel=ATARITT
There are also other options that might be useful, run build.sh without any
arguments to see them.
... my Problem is that all NetBSD Kernels "netbsd-ATARITT" don´t boot
on my Atari TT Maschine. No matter with Version !
Only the netbsd-boot and bootx kernel´s boot on my Machine.
We now have a new developer who is interested in getting the Atari port up
and running again, so we should start to fix bugs again soon.
Thanks,
