Autor Thema: File Transfer  (Gelesen 12951 mal)
Offline x86vet
File Transfer
« am: Mo 20.02.2023, 19:02:59 »
The Tech Note attached may be of interest to some members of this forum.
« Letzte Änderung: Mo 20.02.2023, 20:08:48 von x86vet »
Offline KarlMüller
Re: File Transfer
« Antwort #1 am: Sa 25.02.2023, 19:25:40 »
Thanks for the info.
PC Card Drive:
Is in the control register b8 and b9 not used?
Offline x86vet
Re: File Transfer
« Antwort #2 am: So 26.02.2023, 23:20:29 »
The control register has only 8 bits, b7..b0. When you say b8 & b9, which bits are you asking about?
Offline KarlMüller
Re: File Transfer
« Antwort #3 am: Mo 27.01.2025, 10:35:57 »
Was my fault.
What I mean, is it correct when you read the control register b4 show you the status from the drive? Bit is zero is OK or bit is one it have an error.
Offline x86vet
Re: File Transfer
« Antwort #4 am: Sa 15.02.2025, 08:21:25 »
Control register b4 can be read to determine if the card is present or not.  If it's zero, the card is present.
