Autor Thema: EmuTOS 1.2 veröffentlicht!  (Gelesen 21474 mal)
« am: So 07.08.2022, 13:59:34 »
Heute mal auf Englisch:
With great pleasure the EmuTOS developers can announce the release of EmuTOS 1.2, aggregating one year of productive work since the last release.
As always, you can download the release from our SourceForge page:
https://sourceforge.net/projects/emutos/files/emutos/1.2/
Changes since 1.1.1:
Major changes:
- AES: Add support for 3D objects (enabled in 512k ROMs and PRG)
- AES: Add support for new menu_xxx() functions in AES 3.30
- AES: Allow up to 16 windows for versions with AES 3.30 support
- BIOS: Add interrupt-driven I/O for SCC serial ports
- EmuDesk: Resize screen memory in videl modes, just like TOS4
- General: Make FireBee ROMs single-language
- VDI: Fix crash under FreeMiNT with memory protect enabled
Other changes:
- AES: Display better error message if program launch failed
- AES: Improve error checking for wind_xxx() functions
- AES: Better looking separators in menus
- BDOS: Implement undocumented TOS function Srealloc()
- BIOS: Add support for IKBD/MIDI error vectors
- BIOS: Increase timeout for IDE transfers
- EmuDesk: Fix bug in 'Set file mask...'
- EmuDesk: Fix drag'n'drop bug with desktop icons
- EmuDesk: Display the 'busy' mouse cursor for some lengthy actions
- VDI: Allow Falcon video modes to be set in v_opnwk()
- VDI: Implement v_hardcopy()
- VDI: Speed up some VDI calls
- XBIOS: Implement undocumented TOS function VcheckMode()
- Many minor and/or obscure bugs have been fixed
« Letzte Änderung: So 07.08.2022, 14:02:02 von czietz »
guest4334
Re: EmuTOS 1.2 veröffentlicht!
« Antwort #1 am: So 07.08.2022, 14:23:15 »
super vielen Dank
Liebe Grüße von Siegfried
« Antwort #2 am: So 07.08.2022, 18:41:52 »
Es geht ordentlich voran. Sehr gut und danke!
An dieser Stelle der Hinweis, dass Cloudy, Cloudy-Storm-ST und auch die neue Turbothunder EmuTOS gleich hardwareseitig mitbringen.
« Antwort #3 am: So 07.08.2022, 18:44:34 »
Wie üblich bei einem neuen EmuTOS-Release wird ein Updater für unsere Hardware natürlich bald (= in einigen Tagen) zur Verfügung stehen.
Offline ossc
« Antwort #4 am: So 07.08.2022, 20:38:51 »
Vielen Dank für die Info, ich habe es gerade gesplittet und gebrannt - wunderbar, ein neues
Betriebssystem.
VG Peter
Offline MJaap
  • ST-Computer
« Antwort #5 am: So 07.08.2022, 20:50:33 »
Es freut mich auch sehr, dass es zwei Features von mir in das Release geschafft haben: Die Nicelines ("Better looking separators in menus") ab dem 256KB ROM und Dialogtitel (MagiC/XAES-kompatibel) ab den 512er ROMs  :)
Offline Nervengift
« Antwort #6 am: So 07.08.2022, 21:06:26 »
Geht immer mehr in Richtung TOS 4! 8) Vielleicht wird irgendwann ja sogar nochmal TOS 5 draus. ;D
Offline Stephan L.
« Antwort #7 am: Mo 08.08.2022, 10:42:25 »
was darf man sich unter AES3D vorstellen?
« Antwort #8 am: Mo 08.08.2022, 12:46:00 »
Betrifft hauptsächlich Buttons. Die sehen dann "eingedrückt" aus wenn du sie betätigst, so wie in TOS 4.x auch. Funktioniert aber nur in Farbauflösungen. Und ist wie im README beschrieben auch nur in den 512k ROMs vorhanden.
« Antwort #9 am: Mo 08.08.2022, 12:58:59 »
Betrifft hauptsächlich Buttons. Die sehen dann "eingedrückt" aus wenn du sie betätigst, so wie in TOS 4.x auch. Funktioniert aber nur in Farbauflösungen...
Tatsächlich ist Farbe dafür nicht unbedingt nötig, der 3D Look stellt sich ebenso - wenn auch wesentlich weniger eindrucksvoll - in monochrom ein
« Letzte Änderung: Mo 08.08.2022, 18:14:55 von mfro »
Offline MJaap
  • ST-Computer
« Antwort #10 am: Mo 08.08.2022, 13:37:18 »
Fehlt doch nicht mehr viel, oder? ;)
Offline Stephan L.
« Antwort #11 am: Mo 08.08.2022, 21:15:59 »
Danke für die Info.
guest4334
« Antwort #12 am: Fr 12.08.2022, 22:29:07 »
Emutos 1.2 für den Amiga ist auch auf aminet.net
zufällig gefunden
https://aminet.net/package/misc/emu/emutos
EmuTOS 1.2.1 veröffentlicht!
« Antwort #13 am: Di 16.08.2022, 20:55:26 »
EmuTOS 1.2.1 fixt zwei seltene Bugs im AES, die nach dem 1.2-Release gemeldet wurden:
https://sourceforge.net/projects/emutos/files/emutos/1.2.1/
« Antwort #14 am: Sa 20.08.2022, 09:24:38 »
Ich finde extra repos nicht gut, die Amiga Version ist auch bei emutos zu Laden
zufällig gefunden
« Antwort #15 am: Sa 20.08.2022, 11:49:05 »
Ich seh da überhaupt kein Problem. Die stellen halt die emutos version für Amiga in einem Format zur Verfügung, das für Amiga-Benutzer einfacher zu installieren ist. Im Grunde nix anderes als wenn du für Linux zig opensource Pakete in *.deb oder *.rpm zur Verfügung stellst.
Ausserdem ist das kein eigenes repo (auch kein fork), sondern lediglich das Archiv umgepackt in *.lha, zusammen mit dem Readme das man sich schon anschauen kann ohne das Archiv runter zu laden. Also meiner Meinung nach lediglich Extra-Service für Amiga-Benutzer.
