Autor Thema: Low Cost Fujinet v1.6 - Includes USB and Coleco Adam hardware components  (Gelesen 5379 mal)
Offline mast-eries
Greetings,
A new batch of minimalistic and Low Cost General Purpose Fujinet v1.6
These are called general purpose, due to the interface its not only dedicated to Atari 8 bits computers;
the unit is detachable, a DB15 to SIO, DB15 to DIN6, DB15 to RJ12, DB15 to DB19...
allows you to connect the Fujinet v1.6 to each supported computer such Atari 8 bits - Commodore 64 - Coleco Adam
The unit includes all the hardware elements of Fujinet v1.6, also the Coleco Adam interface components.
Via jumpers, you can select the desired operation, if Atari 8 bits SIO (C64 as well) or if you desire Coleco Adam Interface.
As well, the unit can be powered externally, or via the SIO interface. There is a jumper to change this selection.
The USB interface is included, in order to update the device.
Microcontroller is the same, an ESP32 WROVER with 16 MB flash and 8 MB PSRAM
A video, using this low cost Fujinet in an Atari 65XE:
https://www.youtube.com/watch?v=_1_GGwkDpXk
Price of an unit if 59€ (comes with an Atari SIO cable);
each additional cable such C64 - Coleco Adam takes 8€ per cable
plus 6€ of tracked shipment to Spain, or 9€ for Europe, or 10€ for USA, or 11€ for rest of the world.
