Autor Thema: Mega STE ohne Steuer PAL/GAL laufen lassen ...  (Gelesen 82215 mal)
Online Lukas Frank
Re: Mega STE ohne Steuer PAL/GAL laufen lassen ...
« Antwort #20 am: Mo 07.10.2019, 16:02:28 »
Sind nur noch zwei mit Klammern ...
PART NUMBER: C301905©001
DEVICE: PAL 16L8©15
CHECKSUM: $5297
TITLE: CACHE CONTROL LOGIC AND PROCESSOR CLOCK MUX (CCTL)
îPIN   NAME         PIN   NAMEï
1   A23         11   RW
2   A22         12   CLK16B
3   CLK16      13   CLK8SEL_L
4   CLK8         14   LWE
5   A21         15   UWE
6   MATCH      16   XDTACK
7   A20         17   CAV
8   LDS         18   CTWE
9   UDS         19   CLK
10   GND         20   VCC
STRING C8S 'CLK8SEL_L'
/LWE   =   (/UDS * /LDS * /XDTACK + /UDS * LDS * /XDTACK * RW
         + UDS * /LDS * /XDTACK * MATCH + UDS * /LDS * /XDTACK * RW)
         * /CAV * C8S
/UDE   =   (/UDS * /LDS * /XDTACK +/UDS * LDS * /XDTACK * RW
         + /UDS * LDS * /XDTACK * MATCH + UDS * /LDS * /XDTACK * RW)
         * /CAV * C8S
/CTWE   =   (/UDS * /LDS * /XDTACK + /UDS * LDS * /XDTACK * RW
         + UDS * /LDS * /XDTACK * RW) * /CAV * C8S
CLK   =   /C8S * CLK8 + C8S * CLK16
CLK16B   =   /CLK16
CAV   =   A23 * A22 * /A21 + A23 * A21 * A20 + A32 * /A22 * A21
PART NUMBER: C301907©001
DEVICE: PAL 16R4©15
CHECKSUM: $3A35
TITLE: STROBE LATCH / MISC GLUE (RSTBS)
îPIN   NAME         PIN   NAMEï
1   CLK         11   EN
2   XAS         12   NOMATCH
3   CTRIN      13   CTROUT
4   RW         14   RLDS
5   UDS         15   RUDS
6   LDS         16   RRW
7   AS         17   RAS
8   CACHE_EN      18   BG0
9   BGI         19   BERR
10   GND         20   VCC
RLDS   =   LSD
RUDS   =   UDS
RAS   =   AS
RRW   =   RW
NOMATCH   =   /CACHE_EN
NOMATCH.TRST   =   CACHE_EN
/BGO   =   (/RW * /AS * /XAS + /RUDS * /RW * /AS
         + /RW * RUDS * /RLDS * /AS + AS) * /BGI
CTROUT   =   CTRIN * /CACHE_EN * BERR
guest522
« Antwort #21 am: Di 08.10.2019, 10:26:03 »
DEVICE: PAL 16L8©15
CHECKSUM: $5297
îPIN   NAME         PIN   NAMEï
1   A23         11   RW
2   A22         12   CLK16B
4   CLK8         14   LWE
5   A21         15   UWE
6   MATCH      16   XDTACK
7   A20         17   CAV
8   LDS         18   CTWE
9   UDS         19   CLK
10   GND         20   VCC
/LWE   =    /UDS * /LDS * /XDTACK * /CAV * C8S
         + /UDS * LDS * /XDTACK * RW * /CAV * C8S
         + UDS * /LDS * /XDTACK * MATCH * /CAV * C8S
         + UDS * /LDS * /XDTACK * RW * /CAV * C8S
/UDE   =   /UDS * /LDS * /XDTACK * /CAV * C8S
         + /UDS * LDS * /XDTACK * MATCH * /CAV * C8S
/CTWE   =   /UDS * /LDS * /XDTACK * /CAV * C8S
CLK16B   =   /CLK16
guest522
« Antwort #22 am: Di 08.10.2019, 10:27:41 »
DEVICE: PAL 16R4©15
CHECKSUM: $3A35
îPIN   NAME         PIN   NAMEï
1   CLK         11   EN
2   XAS         12   NOMATCH
3   CTRIN      13   CTROUT
4   RW         14   RLDS
5   UDS         15   RUDS
6   LDS         16   RRW
7   AS         17   RAS
8   CACHE_EN      18   BG0
9   BGI         19   BERR
10   GND         20   VCC
RLDS   =   LSD
RUDS   =   UDS
RAS   =   AS
RRW   =   RW
NOMATCH   =   /CACHE_EN
/BGO   =   /RW * /AS * /XAS * /BGI
          + /RUDS * /RW * /AS * /BGI
         + /RW * RUDS * /RLDS * /AS * /BGI
       + AS * /BGI
Nur ausmultipliziert. Keinerlei Minimierung durchgeführt.
Online Lukas Frank
« Antwort #23 am: Di 08.10.2019, 12:46:05 »
Vielen Dank ...
Fraglich ist noch ob die Sachen da im original für unterschiedliche PAL Bausteine entworfen mit normalen GALs 16V8 gehen ???
Ich lasse mal mit JEDI die JED Dateien bauen und nehme mal meinen Mega STE auseinander und Teste die ganzen GALs ...
« Letzte Änderung: Di 08.10.2019, 12:49:43 von Lukas Frank »
Online Lukas Frank
« Antwort #24 am: Mi 09.10.2019, 18:43:22 »
Ich konnte mit JEDI von allen Quellen die JED Dateien bauen lassen ausser C301905 und C301909
------- 905 ---
ATARI MEGA STE  C301905-001
LOCATION U012
CHECKSUM $5297
TITLE CACHE CONTROL LOGIC AND PROCESSOR CLOCK MUX (CCTL)
                     ___  ___
                A23 |1     20| VCC
                A22 |2     19| CLK
              CLK16 |3     18| CTWE
              CLK8 |4     17| CAV
                A21 |5     16| XDTACK
              MATCH |6     15| UWE
                A20 |7     14| LWE
                LDS |8     13| CLK8SEL_L
                UDS |9     12| CLK16B
                GND |10    11| RW
                    |________|
%ID
    C301903
%TYP
    GAL16V8A
%PINS
    A23  A22  CLK16  CLK8  A21  MATCH  A20  LDS  UDS
    RW  CLK16B  CLK8SEL_L  LWE  UWE  XDTACK  CAV  CTWE  CLK
%LOGIC
C8S = CLK8SEL_L;
         + UDS * /LDS * /XDTACK * RW * /CAV * C8S;
CLK   =   /C8S * CLK8 + C8S * CLK16;
CLK16B   =   /CLK16;
CAV   =   A23 * A22 * /A21 + A23 * A21 * A20 + A32 * /A22 * A21;
%END
------- error ---
Error A:\C301905\C301905.LCI 29:  'C8S' ist kein Ausgang!
------- 909 ---
ATARI MSTE:  CHIP C301909�001
GAL22V10
U407 / CLOCK CONTROL (CLKCTL16)
                             ___  ___
                      CLK16 |1     24| VCC
                      X86OE |2     23| CLK2
                        XIO |3     22| SCLK
                       XLDS |4     21| D0
                        XAS |5     20| D1
                        RXW |6     19| XVPA
                     XRESET |7     18| FCCSEL
                    XFCODXX |8     17| CLK2A
                         NC |9     16| XDTACK
                         NC |10    15| FCCLK
                         NC |11    14| FDDS
                        GND |12    13| NC
                            |________|
%ID
      C301909-001
%TYP
      GAL22V10
%PINS
CLK16  X86OE  XIO  XLDS  XAS  RXW  XRESET  XFCODXX  NC  NC  NC
NC  FDDS  FCCLK  XDTACK  CLK2A  FCCSEL  XVPA  D1  D0  SCLK  CLK2
%LOGIC
SCLK   =   /SCLK;
CLK2A   =   SCLK * CLK2A + /SCLK * /CLK2A;
CLK2   =   /CLK2 * CLK2A * SCLK + CLK2 * /CLK2A * /SCLK
         + CLK2 * /CLK2A * SCLK + CLK2 * CLK2A * /SCLK;
FDDS   =   FDDS * RXW + FDDS * XLDS + FDDS * XIO + FDDS * X86OE
         + D1 * /RXW * /XLDS * /XIO * /X86OE;
D1      =   FDDS;
FCCSEL   =   FCCSEL * RXW + FCCSEL * XLDS + FCCSEL * XIO
         + FCCSEL * X86OE + FCCSEL * SCLK
         + D0 * /RXW * /XLDS * /XIO * /X86OE * /SCLK;
D0      =   FCCSEL;
FCCLK   =   FCCSEL * CLK16 + /FCCSEL * SCLK;
D1.TRST   =   /X86OE * /XIO * /XLDS * RXW;
D0.TRST   =   /X86OE * /XIO * /XLDS * RXW;
GLOBAL.RSTF   =   /XRESET;
/XVPA   =   /XAS;
XVPA.TRST   =   /XIO * /XFCODXX * /XAS;
/XDTACK   =   /XAS;
XDTACK.TRST   =   /X86OE * /XIO * /XAS;
%END
------- error ---
Error A:\C301909\C301909.LCI 56:  'XRESET' ist kein Ausgang!
Hat jemand eine Idee wo das Problem liegt ?
« Letzte Änderung: Mi 09.10.2019, 19:50:56 von Lukas Frank »
guest522
« Antwort #25 am: Mi 09.10.2019, 18:53:48 »
versuchs mal so:
------- 905 ---
LOCATION U012
CHECKSUM $5297
                     ___  ___
                A23 |1     20| VCC
                A22 |2     19| CLK
              CLK16 |3     18| CTWE
              CLK8 |4     17| CAV
                A21 |5     16| XDTACK
              MATCH |6     15| UWE
                A20 |7     14| LWE
                LDS |8     13| C8S
                UDS |9     12| CLK16B
                GND |10    11| RW
                    |________|
%ID
    C301903
%TYP
    GAL16V8A
%PINS
    RW  CLK16B  C8S  LWE  UWE  XDTACK  CAV  CTWE  CLK
%LOGIC
CLK16B   =   /CLK16;
%END
Online Lukas Frank
« Antwort #26 am: Mi 09.10.2019, 19:30:36 »
Ja Danke das ging natürlich ...
Zwei Fehler bereinigt und zwar "LDE" soll wohl "LWE" sein und "A32" soll wohl "A23" sein ...
Online Lukas Frank
« Antwort #27 am: Mi 09.10.2019, 19:33:33 »
Bei der 909 kommt ja GLOBAL.RSTF nirgendwo vor !?!
Ein XRESET = /XRESET ist natürlich Blödsinn und geht auch nicht.
XRESET am GAL soll doch ein Eingang sein, oder?
« Antwort #28 am: Do 10.10.2019, 12:50:54 »
Gibt es da auch einen Link zu den Quellen?
C301899-001   = PAL16R4  (SCC-Chip) (UA3)   /Quelltext vorhanden
C301901-001   = PAL20L8  (Bussteuerung) (UA2)   /JED ist vorhanden
C301903-001   = PAL16L8  (FPU Chipselect) (UB1)   /JED ist vorhanden
C301904-001   = GAL22V10 (Bussteuerung) (U6)
C301905-001   = PAL16L8  (Cache) (U12)   /Quelltext vorhanden
C301906-001   = GAL22V10 (Bussteuerung) (U3)
C301907-001   = PAL16R4B (Cache) (U2)   /Quelltext vorhanden
C301908-001   = PAL16L8A (VME BUS) (U904)   /Quelltext vorhanden
C301900-002   = PAL16L8  (VME BUS) (U903)
C301909-001   = PAL20L8  (Blitter-Chip) (U407)   /Quelltext vorhanden
C301898-001   = GAL22V10 (U11)   /Quelltext vorhanden
Da sind noch zwei weitere JED Dateien die aber glaube ich nichts mit dem MSTE zu tun haben und zwar Mode_HD und Mode_26.
Online Lukas Frank
« Antwort #29 am: Do 10.10.2019, 12:56:02 »
Atari HQ CD ...
->   https://docs.dev-docs.org
« Letzte Änderung: Do 10.10.2019, 12:57:33 von Lukas Frank »
guest522
« Antwort #31 am: Do 10.10.2019, 13:32:57 »
Leider kenne ich PALASM nicht wirklich. Das scheint eine Art globale Reset Funktion zu sein.
http://bitsavers.informatik.uni-stuttgart.de/components/mmi/palasm_pleasm/PALASM_2_Software_Jul87.pdf
Evtl. solltest Du mal eine andere Software versuchen wie PALASM oder OPAL....
GLOBAL.RSTF   =   /XRESET; bedeutet wohl: Reset aller Macro Zellen wenn XRESET low ist.
Online Lukas Frank
« Antwort #32 am: Do 10.10.2019, 13:46:59 »
Ja das habe ich auch gedacht beim Gassi gehen mit dem Hund. Aber da sollte doch alles Fest sein bei einem GAL oder PAL. Ist doch keine Art CPU die einen Reset braucht. Der Ursprungszustand ist doch immer gegeben, oder?
Vielleicht kann ein JEDI Profi wie @pakman weiterhelfen?
Offline Guus.Assmann
« Antwort #33 am: Do 10.10.2019, 16:25:14 »
Manche Programierbare Logic Bausteine haben Flip-Flops in die I/O-Blocks.
Hat also bestimmt zweck um die in den richtigen Zustand zu bringen nach ein Power-up.
Diese Elemente gibt es auch in den Gal 16/20/22.
MFG/
Guus
Online Lukas Frank
« Antwort #34 am: Do 10.10.2019, 17:03:38 »
Danke Guus ...
Dann brauche man ein JEDI Handbuch. GLOBAL.RSTF versteht JEDI ja wohl nicht, oder?
Intern hat ein GAL22V10 einen internen Reset für alle FlipFlops. Fragt sich nur wie man das ansprechen kann mit JEDI?
Pin7 ist ein Eingang und kann nicht Ausgang sein.
Online Lukas Frank
« Antwort #35 am: Do 10.10.2019, 18:28:40 »
Habe da etwas gefunden ...
->   https://www.mikrocontroller.net/attachment/20953/GAL-ASM-Starterkit_Manual.pdf
Function Description --------------------------------------------------------------
TRST Programmable TRIST A TE function SETF Programmable SET function
RSTF Programmable RESET function
CLKF Programmable CLOCK function
HOLD Programmable ENABLE function
TRST is the most commonly used function. It is required in devices that have tristate outputs controlled by a product term.
Example: O1.TRST = P1
A SETF functional equation sets the registered outputs to logic 1 when the logic expression is high.
A RSTF functional equation resets the registered outputs to logic 0 when the logic expression is high.
A CLKF functional equation is used in devices with a programmable clock function for registered outputs.
Online Lukas Frank
« Antwort #36 am: Do 10.10.2019, 18:45:32 »
Egal wie ich die Zeile umbaue JEDI bemängelt immer das es kein Ausgang ist. Ist wohl der Pin7 gemeint.
/RESET kann man ja so nicht definieren.
Reset ist ja low Aktiv. Wenn ein Reset am Pin7 ansteht soll die Funktion "GLOBAL.RSTF" GAL intern einen Reset ausführen.
« Antwort #37 am: Do 10.10.2019, 18:50:01 »
Hallo Frank,
Da gibt's noch etwas.
Wie ein Jedec-Datei aufgebaut ist, ist eigentlich quasi ein Standard.
Den Jedec-Datei wird von den Programmer in den Chip eingespeist / Programiert.
Dies ist Hardwaremassig bestimmt vor Hersteller.
Aber die Assembler sind vergleichbar mit Basic. (XL, XE, Turbo, Omicron, GFA, nicht alle Cambridge standard)
Im grossen und gansen sind die "Befehle" gleich. Aber Syntacs mag etwas anders sein.
Wie zum Beispiel ob ein ' nötig ist nach jede Zeile, oder vielleicht ; oder auch / .... \
So gibt es auch Unterschiede in "Reservierte Wörter" wie TRST, CLKF usw.
Also doch etwas mehr complexe Frage...
MFG/
Guus
Online Lukas Frank
« Antwort #38 am: Do 10.10.2019, 18:59:44 »
Ja schon ausprobiert, geht aber nicht.
guest522
« Antwort #39 am: Do 10.10.2019, 20:50:31 »
versuch mal statt
für jeden Ausgang
XXXX.R =   /XRESET;
also z.b.:
SCLK   =   /SCLK;
SCLK.R =   /XRESET;
CLK2A.R  =   /XRESET;
CLK2.R =   /XRESET;
usw.
