Autor Thema: TT030 with VME Crazydots  (Gelesen 6882 mal)
Offline TXG-MNX
« am: Mi 25.07.2018, 14:26:37 »
Can someone help to get the original installation disks voor de VME Crazydots driver.
I have download from many source only thing I had was a sync on my second monitor with a blank blue screen.
I had installed nvdi 5 no succes, but I never worked with nvdi I only selected ET4000 from the menu at installation.
Also someone pointed me to the recent megaste nova/crazydots driver also no succes.
So if someone with a TT has this card running please help me and share your auto folder + config
Re: TT030 with VME Crazydots
« Antwort #1 am: Mi 25.07.2018, 14:44:25 »
Nova CD Driver Mega STE ->   https://silicon-heaven.org/atari/nova/MegaSTE/CrazyDots/
Autofolder order: 1.emulator.prg 2. menu.prg or xmenu.prg 3. sta_vdi.prg
NVDI ET4000 or NVDI 5 install option ET4000. Your have to create the file nvdivga.inf frist with the VMG program. Place the nvdivga.inf file into the auto folder.
« Letzte Änderung: Mi 25.07.2018, 14:52:13 von Lukas Frank »
Offline TXG-MNX
« Antwort #2 am: Mi 25.07.2018, 21:17:40 »
I finally get it to run with nvdi v5
The vme card is a v1 + color upgrade
It runs ok in 800*600 32k or 1024*768 256
there is a mode 1280*960 2 color but my monitor needs 1280*1024 did try to get this to work no luck anyone here got that resolution to work ?
