Autor Thema: Atari TT floppy drive  (Gelesen 7142 mal)
Offline damanloox
« am: Fr 11.05.2018, 16:51:18 »
I'm looking for working Atari TT floppy drive (direct replacement ie. Atari faceplate) and HD.
Re: Atari TT floppy drive
« Antwort #1 am: Sa 12.05.2018, 00:15:30 »
Do you have such a floppy drive, defective?
It should be an Epson SMD-340. Just have a look after any working Epson SMD-340 drive and get it. You can swap over the floppy's front bezel from your defective drive.
« Antwort #2 am: Sa 12.05.2018, 08:47:44 »
SMD-340 and SMD-300 is good for the swap, others not ...
On Ebay there are black Stacy Epson front-cover.
Offline damanloox
« Antwort #3 am: Di 15.05.2018, 08:48:49 »
Thanks guys but... how do you actually remove faceplate without destroying it? I have smd-340 at home but I don't have any idea how to remove the faceplate...
« Antwort #4 am: Di 15.05.2018, 09:33:46 »
There are hooks at the left and right side of the front bezel of the drive. They are just clipped in.
« Antwort #5 am: Di 15.05.2018, 09:35:48 »
At the metal cover there is a little screw ...
« Antwort #6 am: Di 15.05.2018, 09:40:40 »
You may have to remove the top cover of the drive to see it.
« Antwort #7 am: Di 15.05.2018, 09:42:43 »
It may be helpful to remove the metal cover first to see where the panel is attached. It may also be that it is just locked, then pull carefully.
Offline damanloox
« Antwort #8 am: Mi 16.05.2018, 10:15:16 »
Thanks! Will give it a try this weekend...
