Autor Thema: HATARI 2.1.0 ist da!  (Gelesen 10681 mal)
« am: Do 08.02.2018, 13:27:12 »
Major highlights of this new version :
    - Major rewrite of the YM2149 with a new cycle accurate emulation
    - Major rewrite of the blitter to allow cycle exact bus accesses and correct bus sharing with the CPU
    - Improved video emulation : bottom border at 60 Hz and number of displayed lines, video counter reloading, timer B in mono mode
    - Add full support for MMU/MCU RAM configuration at $FF8001, support more RAM combinations (256 KB and 2.5 MB)
    - Some STX floppy images were not correctly emulated when verify bit was set in the FDC
    - Support for undocumented STOP behaviour on 68000
    - Fix some rare bus accesses order and stack frames
    - Fix some flags after DIV and BCD instructions
    - Improved memory timing for 68030 depending on RAM type
    - 68030 instruction cache was not correctly disabled when EI=0 in CACR
    - Improve caches accuracy for 68020/30/40/60, with optional MMU support
    - Large improvements to FPU emulation, including a new softfloat method
    - MIDI support for Windows and macOS (with PortMidi library)
    - Add support for AVI files > 4GB (up to 256 GB)
    - SDL UI shows refresh rate and blitter usage
    - Several improvements/fixes when using VDI
    - Improvements/more options for autostart using virtual INF file
    - Many improvements to debugger, especially for symbols handling
    - Fix compilation for more targets (ARM64, MIPS, ...)
See release-notes.txt for the full changelog.
Fixed demos : Sprite32 by Leonard, Jam-Cols by ICE, 4getful, Beams, many Falcon demos should run better
Fixed programs : Hextracker for Falcon, Protracker 2.1 and Neochrome Master 2.8 at 60 Hz, Audio Sculpture
Download über http://hatari.tuxfamily.org/
Interessant, dass HATARI mit STX-Images umgehen kann!
Re: HATARI 2.1.0 ist da!
« Antwort #1 am: Do 08.02.2018, 17:18:29 »
STX Support ist schon seit 1.8 oder früher drinn. Ja sehr gut, vorallem, in Hatari ohne eine DLL mit Nagscreen und under Nicht-Windows-Systemen.
Offline MJaap
  • ST-Computer
« Antwort #2 am: Sa 10.02.2018, 16:35:33 »
Ich finde es eigentlich viel interessanter, dass man jetzt auch den 130ST und den "echten" 260ST emulieren kann. Das Hatari-Team hat Humor  ;)
« Antwort #3 am: Sa 10.02.2018, 22:26:06 »
Wieso, ich wollte schon immer mal gucken, ob das RAM-/Floppy-TOS wirklich als ersten Menüpunkt "Desk-Info" hat, statt "DESKTOP". Und das geht am schönsten auf einem 260ST :)
