Autor Thema: Seagate ST32550N extern am TT und Falcon030  (Gelesen 6309 mal)
guest3306
« am: Di 01.01.2013, 22:17:16 »
Bei diesem Testkandidaten handelt es sich um eine schnelle 7200U/min HDD aus dem Hause Seagate:
Seagate Barracuda ST32550N 2GB 50pol SCSI
Hier das eingestellt Jumpersetting:
Ein externer Terminator wurde gesetzt!
Settings:
Terminal J1: (nur die Brücke 1-3 ist gesetzt (ON) ; alle anderen Brücken nicht (OFF)!)
1-2:
Terminator power from the drive (drivesupplies terminator power to its own terminators).
1-3:
Terminator power to the SCSI bus (drive supplies power to an external terminator)
2-4:
Terminator power from the SCSI bus (drive receives terminator power from the SCSI bus–usually the host controller)
1-3 und 2-4:
Terminator power to the SCSI bus and drive (drive supplies termination power to its own terminators and to the SCSI bus)
5-6:
Enable SCSI termination. Jumper installed enables the internal termination on the drive. Jumper removed disables the drive’s internal terminators.
Terminal J2: ( 5-6 ist gesetzt (ON) ; alle anderen sind nicht gesetzt (OFF) )
   1-2 Reserved
   3-4 Reserved
   5-6 Disable SCSI parity
   7-8 Write protect
 9-10 Enable motor start. Jumper installed causes the drive to wait for the Start Unit command from the SCSI host. No jumper installed causes the drive to look at the Delay Motor Start jumper. Default is no jumper.
11-12 Delay motor start. Jumper installed causes a 10-second delay for each SCSI ID number plus a maximum power-up delay of 3 seconds before starting the spindle motor automatically.Default is no jumper.
Example:If SCSI ID is equal to three (3)(3 x 10) +3 = 33 The drive’s spindle motor starts in 33 seconds.
13-14 Reserved
15-16 Reserved
17-18 Reserved
Terminal J4: ( die zwei Brücken 9-10 sowie 11-12 sind gesetzt (ON) für ID 06.00 ; alle anderen sind nicht gesetzt (OFF))
    1-2 Reserved
    3-4 Remote LED connector
    5-6 Spindle sync cable connector
    7-8 SCSI ID bit 0
  9-10 SCSI ID bit 1
11-12 SCSI ID bit 2
13-14 Reserved
15-16 Reserved
17-18 Reserved
19-20 Reserved
An den TT gehangen mit ID 6 als letztes Gerät mit externem Terminator wird die HDD mit HDDRIVER 8.45 einwandfrei erkannt und ist nach starten des Programms HDRUTIL auch im Auswahlmenue für das Partionieren und Formatieren auswählbar. Das Formatieren (default 512 Bytes/Sector) der Festplatte klappte einwandfrei. Nach der Formatierung wurden fünf Partitionen (4x 500.0 MB ; 1x 48.2 MB) erstellt. Nach erfolgtem Reboot wurde die Platte einwandfrei erkannt. Die anschließend durchgeführten Schreib-, Lese- und Löschtests verschiedener Dateien verlief erfolgreich.
Im nächsten Schritt wurde die HDD als einzigstes Gerät an den SCSI-Bus des Falcon 030 mit ID 6 als letztes Gerät mit externem Terminator gehangen. Auch hier wird die HDD mit HDDRIVER 8.45 einwandfrei erkannt und ist nach starten des Programms HDRUTIL auch im Auswahlmenue für das Partionieren und Formatieren auswählbar. Der entsprechende Test für Formatierung und Partitionierung der Platte verliefen erwartungsgemäß einwandfrei. Die anschließend durchgeführten Schreib-, Lese- und Löschtests verschiedener Dateien verliefen ebenfalls erfolgreich.
