Autor Thema: Transform 3.3V PCI bus to 5V  (Gelesen 21770 mal)
guest3234
« am: Do 16.02.2012, 14:57:51 »
I draw a tutorial as a picture to explain (well I hope) how to pass from 3.3V to 5V on the CTPCI slot board for all PCI bus... :D
With that, you can use the FALSE UNIVERSAL PCI boards (VIO forced to 5V like a famous USB board)) and even some pure 5V designed boards IF you add the keylock on the edge connector... to be able to plug it on CTPCI, sure !
It will be put on my page later, when I'm sure it is working  !  ::)
Yes, I did not test this workaround.
If you test it, I'm be happy because I will not have to loose time to test it  ;-)
PS : PLX is OK for 5V tolerance.
Do the modification on all PCI slots... because if you still the Radeon on 3.3V IO mode and send to it some 5V signals, it may be slowly destroyed on PCI pins.
Offline Beetle
  • Board Moderator
Re: Transform 3.3V PCI bus to 5V
« Antwort #1 am: Do 16.02.2012, 15:50:12 »
Interesting! Thanks for the explanation.
It would not be possible to just feed 5V into the Daughterboards 3.3V input (orange wire) and use 5V cards with added key,  is it?
« Antwort #2 am: Do 16.02.2012, 22:36:37 »
Hallo Rodolphe, many good news in the last time. I have no CT6x/CTPCI but I think 5V support for CTPCI is a milestone... :D
« Letzte Änderung: Do 16.02.2012, 22:40:13 von Arthur »
Athlord
« Antwort #3 am: Fr 17.02.2012, 06:22:41 »
It´s not a milestone - it´s a little modification!  >:D
Cheers
Jürgen
Offline Beetle
  • Board Moderator
« Antwort #4 am: Mo 20.02.2012, 14:54:35 »
Hi Rodolphe,
i just did that mod, thanks!
Greetings,
Beetle
PS: Radeon works in 5V environment, my 5V Realtek
8029 PCI card (false 3.3V key added) gets recognized
in PCI listing - so far so great :)
« Letzte Änderung: Mo 20.02.2012, 19:48:35 von Beetle »
guest3234
« Antwort #5 am: Mo 20.02.2012, 17:59:45 »
I confirm that the modification was tested and is OK.
guest1868
« Antwort #6 am: Mi 29.02.2012, 20:39:28 »
Sorry,
-aber wofür brauche ich den Umbau?
-Oder was ist besser an PCI 5V statt 3,3V?
 Bin halt DAU... ;-)
Offline Ektus
« Antwort #7 am: Mi 29.02.2012, 21:13:54 »
Sorry,
 Bin halt DAU... ;-)
Es gibt einige Karten nur in 5V Ausführung, 3,3V ist relativ selten.
Wer schon alle Funktionen mit 3,3V Karten abgedeckt hat, der braucht den Umbau nicht.
Wer mit TV-Karten oder manchen Netzwerkkarten rumexperimentieren will, der kommt um den Umbau nicht herum.
Mit freundlichen Grüßen
Ektus.
guest1868
« Antwort #8 am: Fr 05.10.2012, 19:27:13 »
Gibt es denn tapfere Streiter die sich um die nötige TV Karten Software kümmern?
Hast Du eine Deiner Karten modifiziert Ektus?
Sollte man eine "normale" 3,3V und eine 5V Modifikation haben?  >:D
Offline Ektus
« Antwort #9 am: Sa 06.10.2012, 08:34:08 »
Nicht daß ich wüßte. Wobei - eigentlich müßte ja GEM-TV vom Milan funktionieren.
Ich habe keine modifiziert, da ich die TV-Option nicht brauche und Grafikkarte, Netzwerkkarte, USB- und Firewire-Karte alle in 3,3V Ausführung drinstecken. Für letztere gibt es zwar keinen Treiber, aber da ist sie wenigstens gut aufgeräumt  ;)
Ektus.
