Has anybody gotten Contiki to work on the ST?
SolderGirl:
Depends on what you want to do.
Transfer files? Check this: https://www.youtube.com/watch?v=_28LFmyKoQc
Direct internet connection? Try STiNG TCP/IP Stack.
I don't think there is a telnet<->serial driver available for telnet BBS's, but i might be wrong.
Since i use the PiModem, i have not searched very far.
Thorsten Otto:
--- Zitat von: SolderGirl am Di 30.06.2020, 16:50:06 --- Try STiNG TCP/IP Stack.
--- Ende Zitat ---
Nice try, wonder how you expect that to work on Contiki ;)
--- Zitat ---I don't think there is a telnet<->serial driver available for telnet BBS's, but i might be wrong.
--- Ende Zitat ---
there is, just search for "tcpser". You run it on a different PC, that is connected to the Atari via Nullmodem, and then connects to some BBS that accepts connections via Telnet. But this is just suitable to connect to such BBS, it is not a general TCP/IP converter.
SolderGirl:
--- Zitat von: Thorsten Otto am Di 30.06.2020, 17:11:36 ---Nice try, wonder how you expect that to work on Contiki ;)
--- Ende Zitat ---
Of course it would run on TOS, not Contiki.
But from the initial Post, i guess @mrdweeb is just looking for a way to get his ST online. And STiNG would do that
--- Zitat von: Thorsten Otto am Di 30.06.2020, 17:11:36 ---there is, just search for "tcpser". You run it on a different PC, that is connected to the Atari via Nullmodem, and then connects to some BBS that accepts connections via Telnet. But this is just suitable to connect to such BBS, it is not a general TCP/IP converter.
--- Ende Zitat ---
That is what the PiModem uses. But is there something that runs natively on TOS?
On DOS/PC there is rlfossil, that emulates a serial port over telnet via ethernet. But i don't think you can use a BBS Terminal software to connect to telnet BBS over the netUSBee directly.
Thorsten Otto:
--- Zitat von: SolderGirl am Di 30.06.2020, 17:19:15 ---i guess @mrdweeb is just looking for a way to get his ST online. And STiNG would do that
--- Ende Zitat ---
from what i understand, he is specifally looking for a way to get Contiki online, and the rs232 is the only interface supported there. For TOS, there are other options than using a serial interface.
--- Zitat ---But i don't think you can use a BBS Terminal software to connect to telnet BBS over the netUSBee directly.
--- Ende Zitat ---
I never tried, but that program just encapsulates the data into telnet protocol. That probably means you can connect to anything that has a telnet server running.
mrdweeb:
Very interesting discussion. Thanks for all the information. I will let you know of any success.
Navigation
[0] Themen-Index
[*] Vorherige Sete
Zur normalen Ansicht wechseln
