Autor Thema: Jaguar Soundproblem!!!  (Gelesen 4531 mal)
guest3181
« am: Do 26.04.2012, 15:16:00 »
hi guys!
I forgot my German, so I write to you in English Language..
My Jaguar has worked fine without problems until now.
I get perfect picture but no sound, it´s connected with the antenna output. Do you have a solution of what the problem can be?
Misiing playing " Wulfenstien" with sound!!!! heheheh
Offline u0679
Re: Jaguar Soundproblem!!!
« Antwort #1 am: Do 26.04.2012, 22:55:44 »
you can turn off / turn on the Sound in the Games by pressing the 0 on the controller.
guest3181
« Antwort #2 am: Sa 28.04.2012, 12:55:02 »
That´s not the problem. Nothing happens. Seems to be a hardware problem.
You sould get some sound when you start upp the Jaguar.
Offline u0679
« Antwort #3 am: Mo 30.04.2012, 15:04:58 »
Try to connect your Jaguar with Scart or Chich or SVideo to your TV.
